AMICUS 18 Section
Results 1 to 27 of 27
    Default Re: AMICUS 18 Section
    Questions:
    1. Prefer link to dedicated section.
    2.Where to buy one (or more ) and how much do they cost, delivered in US.
    3. Free Proton compiler download ? How do YOU get paid from that ?
    4. Will it program without bootloader I E ICSP from PICKit2 ? or replacement for PICKit2 ?
    Ok I just found the answer to Question 2, buy from Crownhill . . . makes question 5.
    5.Are these prices serious ?
     GPS Amicus18 Shield
    £999.99 ex. VAT £1199.99 inc. VAT
    The  Amicus GPS shield contains a 16 channel ZX4120 GPS receiver, as well as  a
    16k byte (128 kbit) serial (I2C) eeprom, and a 1.5 Volt, 12mm   battery socket in
    order to maintain the receiver's built-in RTC (Real  Time Clock). An SMA socket
    allows attachment of the GPS receiver's  aerial.
    Every "SHIELD" listed has a price of 999 pounds sterling, I cannot assume that's correct, is it ?
    Apr 2003
    Cambridge - UK
    Answers to your questions
    1) lets see if there is some interest from PBP users before we rush into making sections or links
    2) Crownhill or Farnell or make your own its an open design and all data is available. There are already MANY clones available.
    3) the Free Proton compiler is only 1 option, the hardware is OPEN and is valid for use with PBP, so why not use PBP???? The bootloader is agnostic, so you can use the bootloader to load your PBP compiled code
    The object of the excersice is to take advanatge of the multitude of Arduino Shields that are available at VERY low cost. AMICUS 18 is simply a hardwrae platform that would enable PBP users to easily take advantage of ther massive amount of shields available.
    4) at least look that the documentation and the schematics, the answer is YES, but for ease of use the Bootloader is FREE and open and works well with PBP
    5) NO, go and buy ARDUINO SHIELDS, the point is that Arduino sheilds are CHEAP and readily available....Before Amicus18 there was no way for a PBP user to take advantage of the massive number of low cost sheilds that were designed for the Arduino. Now a PBP user can use those low cost easily available sheilds in the PIC environment.
    Arduino is probably the MOST POPULAR develkpment platform in the world at present and has been for some time. NO PIC development platform has ever been as popular as the Arduino. Arduino is Atmel based and PBP users cannot take advantage of this popular platform unless they move to Atmel...which they don't want to do. So enter Amicus18.....
    OK I think I will order one of these boards, good to know it is compatible with arduino shields. I thought maybe the "shields" prices listed were just some numbers thrown into the web page during construction which would stand out during editing so they could be changed to the "real price" and got missed, My Bad, your shields are Professional, not hobbyist tools.
    Apr 2003
    Cambridge - UK
    It would be great if a PBP user were to produce some code examples in PBP to replace the examples in the Amicus18 Companion Shield Manual . I think I could persuade tghe author to release the original document so that it could be modified to support PBP code examples.
    Any offers???
    Any offers???
    I am working on a small article, should have it up tonight.
    Apr 2003
    Cambridge - UK
    Hey that would be great, the code examples in the Companion Shield manaul are simple enough, but still PBP users will ahve an easier time if they were to be replaced by PBP examples.
    It would be really good to ahve a PBP Companion shield manaul.....I'm sure we could do that if a few PBP users were to produce equivalent code examples and re write a little of the text in the manaual to reflect useing Amicus18 with PBP instead of Proton
    It was a tough decision... sleep or work on this.. I slept, so it is late....
    I figured starting with MCS and the boot loader would be a good place to begin.
    http://www.picbasic.co.uk/forum/cont...ro-Code-Studio
    I will do some code later.
    Apr 2003
    Cambridge - UK
    re question 3
    Essentially we don't !
    Its like running this forum, and all the other resources we make available to PBP users, we do it because we can, we do it to give something back to the community.
    Apr 2003
    Cambridge - UK
    Amicus18 is available in the USA from NEWARK
    http://www.newark.com/amicus/amicus1...ard/dp/79R5806
    In the UK and Europe from Farnell
    http://uk.farnell.com/amicus/amicus1...s18/dp/1818281
    Amicus18 was presented at the Microchip Masters last fall.
    Apr 2003
    Cambridge - UK
    Before Amicus18, PIC users would look at the Arduino and typically post on forums:
    and now the same people are saying things like:
    As a PIC micro developer for 15 years (yikes) I started to see if there was a project to use the wide range of Arduino shields. The most promising is the Amicus18 from Crownhill, see http://www.myamicus.co.uk/.
    The hardware design is open and based on the Arduino Duemilanove design but with a PIC device.
    Google Arduino and see just how much is going on in that community. Its massive. PBP users can take advantage of the low cost development boards and the plethora of projects and ideas, without having to build from scratch. Simply use the AMICUS18 hardware, and the low cost Arduino shields that plug right in.
    Amicus18 is NOT some wonderful new design, it is NOT special, It is NOT even the best design.
    Amicus18 is beautiful because it enables PBP users to take advantage of low cost Arduino hardware, thats all.
    Its true that if you were to develop a platform from scratch you would probably NOT have developed the Amicus18, but when you consider the advantages of making something thats compatible with Arduino, you see that there is a good reason behind the AMICUS18 development platform....think about it!
    I saw someone using Arduino to interface with online racing software, I haven't checked sim-flight hardware forums recently so I can't talk about that..
    I first thought the Arduino was something like the Basic Stamp. I'm not interested in "that style" of architecture, especially when it's expensive.
    Now if Amicus brings simplicity along with low cost, then it's a whole different ball game.
    Apr 2003
    Cambridge - UK
    Robert, do some research, Ardunio is NOTHING like a Basic Stamp.
    Arduino is to Atmel as the 16F84 was to MCHP in the mid 90's....Arduino has put Atmel on the map and top of the list.
    By their own admission - and i spent a lot of time talking to them about it, MCHP lost ground because of this simple little development board Arduino.
    Arduino is by far the most popular ucontroller development platform in the world today, because its open, low cost and takes leverage from the free tools in the Atmel community.
    MCHP have lost a lot of developers to Atmel because of Arduino, thats fact, Marketeers in both camps agree on that.
    Amicus18 and its clones, simply give PBP and other MCHP users an easy route to take advantage of the mass of development boards - called 'shields' - that support the Arduino. They are abundant and cheap.
    Amicus18 was touted as the Arduino killer by some, its NOT. But is is a vaibale alternative for those PIC users that see whats available to the Atmel community and want the same for themselves.
    Apr 2003
    Cambridge - UK
    why-the-arduino-won <- read this
    Conservative estimates suggest that Arduino shipped 150K + units last year NOT including the clones that originate form the far east !!
    Then there's the estimated 4 or 5 shields used per Arduino, so there are maybe close to 1M sheilds out there in developers tool boxes.
    With volumes like that prices are LOW LOW LOW, so all you need is a open low cost platform onto which you can attach your Arduino shield and then PBP users can take advantage of the "competitors" baby.
    Shields are boards that can be plugged on top of the Arduino PCB extending its capabilities. The different shields follow the same philosophy as the original toolkit: they are easy to mount, and cheap to produce.And they fit directly onto the AMICUS18 board which uses a 3.3V or 5V PIC which you can write code for with PBP !
    Example: http://www.myamicus.co.uk/content.ph...Remote-Control
    Bruce Reynolds shows just how easy it is to use PBP on an Arduino compatible platform
    and here are some shields that you could use with PBP and an Amicus18 board http://www.adafruit.com/index.php?ma...ex&cPath=17_21
    Dont forget the Amicus18 board is open, so you dont have to buy it form Farnell or Newark, or Crownhill, you can build your own - as many people have done. Google microchip 1818281+1818282 to find many more suppliers
    Apr 2003
    Cambridge - UK
    Sorry, i forgot to mention, you can get hold of the hardware from Microchip direct too
    http://www.microchipdirect.com/Produ...ywords=TAES001
