Config 18F25K22
Results 1 to 2 of 2
Thread: Config 18F25K22
    Sep 2006
    Venezuela - Caracas
    Default Config 18F25K22
    i'm try configure 18F25K22 for work 16MHz internal Osc
    code show hserout text wrong and led not blink
       asm
          __CONFIG    _CONFIG1H, _FOSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
          __CONFIG    _CONFIG2H, _WDTEN_OFF_2H & _WDTPS_512_2H
          __CONFIG    _CONFIG3H, _MCLRE_INTMCLR_3H & _PBADEN_OFF_3H
          __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
          __CONFIG    _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L & _CP3_ON_5L
          __CONFIG    _CONFIG5H, _CPB_ON_5H
       endasm
       @ errorlevel -202
    '---[ Serial 1 ]----------------------------------------------------------------
       DEFINE   HSER_RCSTA    90h
       DEFINE   HSER_TXSTA    20h
       DEFINE   HSER_BAUD     9600
       DEFINE   HSER_CLROERR  1
    '---[ Portas ]------------------------------------------------------------------
       Led               var   PORTA.0
    '---[ Váriaveis ]---------------------------------------------------------------
       I                 Var   WORD
       L                 Var   WORD
       J                 Var   BYTE
       K                 Var   BYTE
       Sim               Con   1
       Nao               Con   0
       OSCCON  = %01110000;                         ' 16mHz
       OSCTUNE = %00000000;                         ' 16 MHz PLL Off bit 6=0, 64MHz PLL On bit 6=1
       CM1CON0.7 = 0                                ' Comparadores
       ADCON1 = 15                                  ' Portas A e B Digital
       INTCON2.7 = 0                                ' Ativa Pull-Ups
       ANSELC = 0                                   ' Serial 1
       PORTA = 0
       PORTB = 0
       PORTC = 0
       LATA = 0
       LATB = 0
       LATC = 0
       TRISA = %00000000
       TRISB = %10000000
       TRISC = %10000000
       Led = 1
       pause 3000
       HSEROUT ["> START", 13]
       pause 1
        Led = 0
    '---[ Programa ]----------------------------------------------------------------
    Inicio:
       Led = 0
       pause 3000
       Led = 1
    goto Inicio
    ..: Don't worry, be happy :..
    Default Re: Config 18F25K22
    Add DEFINE OSC 16 somewhere in the beginning, and add a PAUSE after Led = 1.
    Also - ADCON1 = 15 does not do what you think it's doing. Look at the ANSEL registers.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
