HPWM on 16F88
Results 1 to 8 of 8
Thread: HPWM on 16F88
    Jan 2008
    Selm, Germany
    Default HPWM on 16F88
    Hi folks, long time no see!
    Maybe someone is in the mood to help.
    Thanks in Advance.
    try to make an engine water pump driver and Iīm frustrated about my inability to get the HPWM working.
    the °C reading works and the speed change works too but I canīt
    get the RB0 to make it right....I know its in the config thingy..
    Heres my code:
    '* Name : Thermometer-LCD1 + HPWM (only for range 70-90°C) *
    '* Test with 20-23 °C RB0 = HPWM out *
    '* Author : M.David *
    '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 31.03.2011 *
    '* Version : 1.0 for NTC Probe AB 94 098 000.D1 M12 x 1.5 *
    '* Notes : 16F88 LCD 1X16 connected as usual *
    '* : Portb.7 analog IN 0-2V *
    Include "modedefs.bas"
    Define OSC 4
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_SAMPLEUS 100 ' Set sampling time in uSec
    define CCP1_REG PORTB
    DEFINE CCP1_bit 0
    CMCON = 7 ' Disable analog comparator
    ANSEL = %01000000 ' set AN6 (RB7) as analog, others to digital
    ADCON1.7 = 1 ' Right justified results... duh... really needed in 8 bits???
    Uhilf var word
    Uin VAR Word
    Fac var Word
    Multi Var Word
    Uresult var Word
    Temp Var word
    speed var word
    Speed = 0
    LCDOUT $FE,1
    PAUSE 1
    LCDOUT $FE,1,"Pumpensteuerung"
    pause 2000
    LCDOUT $FE,$C0,"Wassertemperatur"
    pause 3000
    HPWM 1,speed,1000
    ADCIN 6, Uin ' Read channel 6 (RB7)
    pause 10
    Uhilf = Uin * 7
    Uresult = Uhilf / 48
    Temp = Uresult / 100
    pause 10
    if Uresult = 21 then
    speed = 0
    if Uresult = 22 then
    speed = 127
    if Uresult = 23 then
    speed = 255
    LCDOUT $FE,1,"Temp=",DEC2 Uresult
    pause 2000
    LCDOUT $FE,1,"Speed",DEC3 speed
    pause 2000
    END ' End of program
    Default Re: HPWM on 16F88
    I think that CCP1 defaults to RB3 and that you, as you say, has to reconfig it to have it on RB0 instead.
    Open 16F88.inc file located in the PBP folder and change the CONFIG line to:
    __config _CONFIG1, _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF & _CCP1_RB0
    Note that there are two lines, one (the one I showed above) if you use MPASM and another if you use PM and they differ slightly in the format used but you'll get the idea.
    Just remember that once you've edited the file it stays that way and if you forget about it you'll scratch your head the next time you're using the F88 and the CCP module doesn't work on RB3.... ;-)
    Jan 2008
    Selm, Germany
    Hi Henrik,
    tried your suggestion, didnīt work.
    thought it was already in the defines, but tried that too.
    Any more ideas?
    thanks
    Now I'm a bit confused, it seems like it IS defaulting to PortB.0 and not PortB.3 as I said earlier, so you shouldn't have to change anything. Either way I've tried it here and it works.... I can switch the PWM output between RB0 and RB3 by changing the CONFIG like shown in the previous message.
    However, I don't see you setting the TRIS register anywhere and I don't know if HPWM does that for you, always best to do that your self.
    If you are using MPASM for the assembler, defines need to be all uppercase.
        DEFINE CCP1_bit 0
    Jan 2008
    Selm, Germany
    Hello Darrel,
    nice you took a look at my childish problem.
    The config files you mentioned were in the upper part of the program
    do I have to put them in the .inc file? Iīm confused.
    And i was so frustrated I wrote code that used Portb.0 as switch
    inside my simple program because I feared the chip was blown but it works.
    it is just: I canīt get portb.0 as HPWM output AND the normal LCDout application at once. The LCD is the reason I canīt switch the port. got the boards already.
    sream, howl, and so on
