Rs232 over long distance
Results 1 to 10 of 10
    Nov 2007
    Lake Villa Il.
    Default Re: Rs232 over long distance
    Thanks Dave,
    Will this one work? It appears to offer full duplex and is isolated, which help with all the RF floating around the site.
    www.serialcomm.com/serial_rs232_converters/rs232_to_rs485_converters/externally_powered_rs232_to_4_wire_rs485_rs422_con verter/ext_rs232_to_4_wire_rs485_rs422.product_general_in fo.aspx
    Thank you again.
    Terry K9HA
    Sneaky-geek
    Dec 2005
    That should work but you should consider whether the opto-isolators are adequate if you have a lot of lightning. The datasheet says they offer 2500V isolation but that's not much where lightning is concerned. RS232 to Fiber Optics would offer much better isolation.
    Nov 2007
    Lake Villa Il.
    Dave,
    You are correct. That would eliminate both lightning and RF problems.
    At the moment, the drawback is the cost. Fiber cable is kinda steep. This is unless there is a low cost (HEY, I'm a HAM and we are noted for being stingy) source for the cable.
    This is the method I would love to use.
    Maybe on E-day (no copyright infringement here!).
    Again, my Thanks to All.
    Terry K9HA
    Sneaky-geek
    Dec 2010
    For the distance and frequencies you are talking, cheap plastic fiber optic cables would do fine. A quick search came up with this: http://fiberopticcables.stores.yahoo...p625-stst.html You can probably do better by spending more time searching.
    Nov 2007
    Lake Villa Il.
    Charlie,
    I will give them a call later today.
    Thank you for the link.
    Terry K9HA
    Sneaky-geek
