Hello! i'm also new here..
I need to send a bmp image to display(HITACHI 640X24 WITH SED13305F) but i don't know how to ,I have a program to convert bmp to asm or bas .
So,my question is: how to include generated files to my program?
'HITACHI LCD 640X240 MONOCHROME
@ DEVICE PIC16F876A  ,PWRT_ON,BOD_OFF,WDT_OFF,LVP_OFF,HS_OSC
DEFINE OSC 10
trisa=%00000000
trisb=%00000000
trisc=%00000000
CMCON = 7
ADCON1= 7			'Make all pins digital
PORTA=0
PORTB=0
PORTC=0
'Set pins for output
dat      var PORTB    ;D0=21 TO D7=28
a0       var PORTC.0   ;11
rd       var PORTC.1   ;12
wr       var PORTC.2   ;13
cs       var PORTC.3   ;14
rst       VAR PORTC.4  ;15
cs = 0
RD = 0
wr=0
'Constants used
SYS_SET		    con	$40
SYS_SLEEP	    con	$53
SYS_CGRAM_ADDR	con	$5C
SYS_SCROLL	    con	$44
SYS_SCROLL_RATE	con	$5a
SYS_CUR_FORM	con	$5d
SYS_CUR_ADDR	con	$46
SYS_CUR_READ	con	$47
SYS_CUR_DIR_RT	con	$4c
SYS_CUR_DIR_LT	con	$4d
SYS_CUR_DIR_UP	con	$4e
SYS_CUR_DIR_DN	con	$4f
SYS_OVER_LAY	con	$5b
SYS_MWRITE	    con	$42
SYS_MREAD	    con	$43
LCD_DISP_ON	    con	$59
LCD_DISP_OFF	con	$58
LCD_INVERSE	    con	$ff
LCD_NORMAL	    con	$00
LCD_GRH         con $960  ;GRAPHIC HOME ADDRESS
LCDL1		con	0	'Line 1
LCDL2		con	80	'Line 2
LCDL3		con	160	'Line 3
LCDL4		con	240	'Line 4
LCDL5		con	320	'Line 5
LCDL6		con	400	'Line 6
LCDL7		con	480	'Line 7
LCDL8		con	560	'Line 8
LCDL9		con	640	'Line 9
LCDL10 CON 720
LCDL11 CON 800
LCDL12 CON 880
LCDL13 CON 960
LCDL14 CON 1040
LCDL15 CON 1120
LCDL16 CON 1200
LCDL17 CON 1280
LCDL18 CON 1360
LCDL19 CON 1440
LCDL20 CON 1520
LCDL21 CON 1600
LCDL22 CON 1680
LCDL23 CON 1760
LCDL24 CON 1840
LCDL25 CON 1920
LCDL26 CON 2000
LCDL27 CON 2080
LCDL28 CON 2160
LCDL29 CON 2240
LCDL30 CON 2320
'General Variables used
gl_cmd		var	BYTE
gl_cur      var BYTE
gl_byte		var	BYTE
gl_i		var	BYTE
gl_j		var BYTE
gl_addr		var	WORD
gl_set      var byte
RST=0
PAUSE 1
RST=1
RD = 1
goto main		'Jump over subroutines
'===== SUBROUTINES ============
'Data
send_dat:
	a0	= 0
	dat	= gl_byte
 goto gl_strobe
'Command
send_cmd:
	a0	= 1
	dat 	= gl_cmd
'Write
gl_strobe:
	wr	= 0
	@ nop
	wr	= 1
	a0   = 0
'Clear Graphic Screen
gl_grfclr:
	gl_cmd = SYS_CUR_ADDR	'CSRW command
	gosub send_cmd
	gl_byte = $60
	gosub send_dat
	gl_byte = $09
	gosub send_dat
	gl_cmd = SYS_CUR_DIR_RT	 'Cur movement right
	gosub send_cmd
	gl_cmd = SYS_MWRITE
	gosub send_cmd
        gl_byte = $00
	for gl_i = 1 to 240      ;pixel  V
	   for gl_j = 1 to 80    ;bytes H
		gosub send_dat
	   next gl_j
	next gl_i
'Clear Text screen
gl_txtclr:
	gosub send_cmd
	gl_byte = $00
	gosub send_dat
	gl_byte = $00
	gosub send_dat
	gosub send_cmd
	gl_cmd = SYS_MWRITE
	gosub send_cmd
	gl_byte = " "	'ASCII Space
	for gl_i = 1 to 30
	   for gl_j = 1 to 80
		gosub send_dat
	   next gl_j
	next gl_i
'Setup LCD
gl_init:
	gl_cmd = SYS_SET
	gosub send_cmd
	for gl_i = 0 to 7
		            'P1  P2  P3  P4  P5  P6  P7  P8
        lookup gl_i,[$30,$07,$07,$4F,$54,$EF,$50,$00],gl_byte
        gosub send_dat
	next gl_i
	'scroll
	gl_cmd = SYS_SCROLL
	gosub send_cmd
	for gl_i = 0 to 5 ' sad1   sl1  sad2   sl2   sad3
		  lookup gl_i,[$00,$00,$EF,$60,$09,$EF],gl_byte
		gosub send_dat
	next gl_i
	'Hdot
	gl_cmd = SYS_SCROLL_RATE
	gosub send_cmd
	gl_byte =$00
	gosub send_dat
	'Overlay
	gl_cmd = SYS_OVER_LAY
	gosub send_cmd
	gl_byte = $01
	gosub send_dat
	'DISP OFF
	gl_cmd =LCD_DISP_OFF
	gosub send_cmd
	gl_byte = %00010110
	gosub send_dat
	'Clear Text screen
	gosub gl_txtclr
	'Clear Graphic screen
	gosub gl_grfclr
	'CSRW set cursor home
	gosub send_cmd
	gl_byte = $00
	gosub send_dat
	gl_byte = $00
	gosub send_dat
	gosub send_cmd
	gl_byte = SYS_MWRITE
	gosub send_dat
	gl_byte = $00
	gosub send_dat
	gl_byte = $00
	gosub send_dat
	'CSR FORM
	gl_cmd =SYS_CUR_FORM
	gosub send_cmd
	gl_byte = $04
	gosub send_dat
	gl_byte = $86
	gosub send_dat
	'DISP ON
	gl_cmd = LCD_DISP_ON
	gosub send_cmd
	gl_byte = $16	'cursor off $35
	gosub send_dat
	'CSR DIR
	gosub send_cmd
'Routine to set the address
gl_setaddr:
	gl_cmd = SYS_CUR_ADDR       'Address command
	gosub send_cmd
	gl_byte = gl_addr.BYTE0     'Vram text memory starts at $0000 and graphics at $960
	gosub send_dat
	gl_byte = gl_addr.BYTE1
	gosub send_dat
	gl_cmd = gl_cur	            'Set cursor movement to left,right,up or down
	gosub send_cmd
'End of subroutines
'  MAIN PROGRAM
	gosub gl_init		'Initialize display
	PAUSE 10
 mesages:
'draw a border around LCD
'Left vert Line
	gl_addr = LCD_GRH + 0 	      'Graphic home position $960 2400
	gl_cur  = SYS_CUR_DIR_DN      'Cur movement to right
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	gl_byte =$ff
	for gl_i = 0 to 239		     ;vertical 240
		gosub send_dat
	next gl_i
'Right vert Line
	gl_addr = LCD_GRH + 79      'Graphic home position $960 2400
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	gl_byte = $ff
	for gl_i = 0 to 239		      ;vertical address
		gosub send_dat
	next gl_i
'Top Line
	gl_cur  = SYS_CUR_DIR_RT      'Cur movement to right
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	gl_byte = $ff		'All bits set
	for gl_i = 0 to 79
		gosub send_dat
	next gl_i
'Bottom Line
	gl_addr  = LCD_GRH + $4AB0;
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	gl_byte = $ff
	for gl_i = 0 to 79
		gosub send_dat
	next gl_i
; Layer 1 text
	gl_addr = LCDL2+1      'Line 1 and 1 bytes to right
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
for gl_i = 0 to 8
		lookup gl_i,["LINIA 2 "],gl_byte
		gosub send_dat
	next gl_i
	gl_addr = LCDL4 + 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
for gl_i = 0 to 8
		      lookup gl_i,["LINIA 4 "],gl_byte
		gosub send_dat
	next gl_i
	gl_addr = LCDL6 + 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 8
	      lookup gl_i,["LINIA 6 "],gl_byte
		gosub send_dat
	next gl_i
  	gl_addr = LCDL8 + 1
	gosub gl_setaddr
  	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
for gl_i = 0 to 47
        lookup gl_i,["LINE 8 "],gl_byte
		gosub send_dat
	next gl_i
	gl_addr = LCDL10+ 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
		 lookup gl_i,["LINIA 10 "],gl_byte
		gosub send_dat
	next gl_i
	gl_addr = LCDL12+ 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
		 lookup gl_i,["LINIA 12 "],gl_byte
		gosub send_dat
	next gl_i
	gl_addr = LCDL14+ 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 57
		    lookup gl_i,["LINE 14 @ HITACHI SP21H001 LCD PANEL 640X240 & SED13305F "],gl_byte
		gosub send_dat
  	next gl_i
	gl_addr = LCDL16+ 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
		lookup gl_i,[" LINE 16 "],gl_byte
		gosub send_dat
	next gl_i
	gl_addr = LCDL18+ 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
         lookup gl_i,["LINIA 18 "],gl_byte
		gosub send_dat
	next gl_i
		gl_addr = LCDL20+ 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
         lookup gl_i,["LINIA 20 "],gl_byte
		gosub send_dat
	next gl_i
			gl_addr = LCDL22 + 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 8
         lookup gl_i,["LINIA 22 "],gl_byte
		gosub send_dat
	next gl_i
			gl_addr = LCDL24 + 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 8
         lookup gl_i,["LINIA 24 "],gl_byte
		gosub send_dat
	next gl_i
				gl_addr = LCDL26 + 1
	gosub gl_setaddr
;	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
         lookup gl_i,["LINIA 26 "],gl_byte
		gosub send_dat
	next gl_i
			gl_addr = LCDL28 + 1
	gosub gl_setaddr
;	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
         lookup gl_i,["LINIA 28 "],gl_byte
		gosub send_dat
	next gl_i
		gl_addr = LCDL30 + 1
	gosub gl_setaddr
	'MWRITE
	gl_cmd =SYS_MWRITE
	gosub send_cmd
	for gl_i = 0 to 9
         lookup gl_i,["LINIA 30 "],gl_byte
		gosub send_dat
	next gl_i
 goto mesages
'   END OF PROGARM
