DS1820 Negative Numbers and OffSet
Results 1 to 6 of 6
    Jun 2010
    Venezuela
    Default Re: DS1820 Negative Numbers and OffSet
    Quote Originally Posted by gadelhas View Post
    Hi everyone once again;
    I made a program to read a DS1820 showing positive and negative temperatures. I found a piece of code in this forum to handle that, and its workinf fine. Now i want to put an offset in the temperature that was readed, for instance if the sensor is at 18șC and the OFFSETTEMP variable is 2, then the LCD shows 20șC, if the OFFSETTEMP variable is -3 than the lcd shows 15șC.
    In the code you will see that i allready have a menu to change the OFFSETTEMP variable, however i don't know now how to interect with the temperature that i'm reading.
    Attached is the Proteus file with the simulation of the code, the code, and the HEX file.
    The "MENU" button its to enter the the menu, and the "+" and "-" button is to change the value of the OFFSETTEMP variable.
    Can somebody give me a clue?
    Here is the code:
    '*  Name    : TESTE DS1820.BAS                                  *
    '*  Author  : GADELHAS                                          *
    '*  Notice  : Copyright (c)                                     *
    '*  Date    : 23-04-2011                                        *
    '*  Notes   : BreadBoard + EASYPICV6                            *
    '*          : PIC16F877A                                        *
    DEFINE OSC 20
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF & _BODEN_OFF & _PWRTE_OFF
    '                               VARIABLES
     TEMPC        Var Word
     OFFSETTEMP   VAR BYTE
     SIGN         var bit
     FLAG         VAR BYTE
    '                         PINOUT 1 = IN; 0 = OUT
              '76543210
     TRISA  = %00000000
     TRISB  = %00000000
     TRISC  = %10010000
     TRISD  = %00001100
     TRISE  = %00000000
     ADCON1 = 7
    '                              ALIAS
     LED     VAR PORTB.7
     BMENOS  var PORTD.2
     BMAIS   var PORTD.3
     BMENU   VAR PORTC.4
     OUT     Var PORTC.2
     DQ      VAR PORTE.2
    '                              DEFINITIONS
     DEFINE LCD_DREG PORTB      ' LCD Data bits on PORTB
     DEFINE LCD_DBIT 0          ' PORTB starting address
     DEFINE LCD_RSREG PORTB     ' LCD RS bit on PORTB
     DEFINE LCD_RSBIT 4         ' LCD RS bit address
     DEFINE LCD_EREG PORTB      ' LCD E bit on PORTB
     DEFINE LCD_EBIT 5          ' LCD E bit address
     DEFINE LCD_BITS 4          ' LCD in 4-bit mode
     DEFINE LCD_LINES 2         ' LCD has 2 rows
     DEFINE LCD_COMMANDUS 2000  ' Set command delay time in us
     DEFINE LCD_DATAUS 50       ' Set data delay time in us
    '                             MAIN
    PAUSE 100
    INICIO:             '01234567890123456789
        Lcdout $fe, 1,  "    DS1820 Teste    "
        Lcdout $fe, $C0,"   HUGO  OLIVEIRA   "
        Pause 1000
    MAIN:
            if Bmenu = 0 then
               Pause 200
               goto  MENU
            gosub SENSOR
            IF SIGN=1 THEN
                Lcdout $fe, $C0, "Temp: -",DEC ABS (TEMPC/10), 223,"C         "
                Lcdout $fe, $C0, "Temp: ",DEC ABS (TEMPC/10), 223,"C          "
    Goto MAIN
    '                          BUTTON ROUTINE
    MENU:
     flag=1
     while flag <> 0
         if flag = 1 then
            Lcdout $fe, $1, "Menu 01-OffSet Temp."
            if OFFSETTEMP.7 = 0 THEN
                Lcdout $fe, $C0,"OffSet: ", DEC abs(OFFSETTEMP)
                Lcdout $fe, $C0,"OffSet: -", DEC abs(OFFSETTEMP)
            gosub PLUSBUTTON
            gosub MINUSBUTTON
        if Bmenu =0 then
            pause 200
            if flag = 1 then
                flag =0
                flag = flag + 1
     wend
    GOTO MAIN
    PLUSBUTTON:
        if Bmais = 0 then
            pause 200
            if flag = 1 then
                if OFFSETTEMP = 5 then
                    OFFSETTEMP = 5
                    OFFSETTEMP=OFFSETTEMP + 1
    MINUSBUTTON:
        if BMENOS = 0 then
            pause 200
            if flag = 1 then
                if OFFSETTEMP = 251 then
                    OFFSETTEMP = 251
                    OFFSETTEMP=OFFSETTEMP - 1
    '                          TEMPERATURE ROUTINE
    SENSOR:
        owout DQ,1,[$CC, $44]
        Pause 200
        owout DQ,1,[$CC, $BE]
        OWIn  DQ, 2, [TempC.byte0, TempC.byte1]
        sign = tempc.15
        TempC = ABS(TempC)
        TempC =(TempC>>1)*10 + (TempC.0 * 5)
    hi(hola) gadelhas,
    i read you program try this:
    SENSOR:
    Pause 200
    sign = tempc.15
    TempC = ABS(TempC)
    ' if OFFSETTEMP = -3 and temperature = 30 tempc=tempc+(-3)=27
    ' if OFFSETTEMP = 3 and temperature = 30 tempc=tempc+(3)=33
    ' put this line in you code look the picture
    ----> Tempc=Tempc+OFFSETTEMP
    Aug 2008
    Portugal
    Quote Originally Posted by scrwld View Post
    hi(hola) gadelhas,
    SENSOR:
    Pause 200
    sign = tempc.15
    TempC = ABS(TempC)
    Hi scrwld ;
    it dosen't work like should be.
    But still trying.
    EDIT:
    After trying other things with your line of code, it doesn't work like should be.
    However thanks for watching and answering my post.
    Thanks and Regards;
    Gadelhas
    May 2008
    Italy
    Why don't you use two different offsets? If you use N_OffSet for the negative number and P_OffSet for the positive number the operation will be:
    LCD_Temperature = Sensor_Temperature + P_OffSet - N_OffSet
    You have simply to set to zero the value not used.
    Cheers
    Al.
    Aug 2008
    Portugal
    Quote Originally Posted by aratti View Post
    Cheers
    Al.
    I Al,
    It's a good idea, but i allready resolved the problem just with one variable, and it works like a charm. You can see my solution in the second post of this thread.
    Thanks.
    Thanks and Regards;
    Gadelhas
