DS1820 Negative Numbers and OffSet
Results 1 to 6 of 6
Threaded View
  1. #2
    Aug 2008
    Portugal
    Default Re: DS1820 Negative Numbers and OffSet
    Hi again;
    I allready found it out.
    Here is the code:
    '*  Name    : TESTE DS1820.BAS                                  *
    '*  Author  : GADELHAS                                          *
    '*  Notice  : Copyright (c)                                     *
    '*  Date    : 23-04-2011                                        *
    '*  Notes   : BreadBoard + EASYPICV6                            *
    '*          : PIC16F877A                                        *
    DEFINE OSC 20
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF & _BODEN_OFF & _PWRTE_OFF
    '                               VARIABLES
     TEMPC        Var Word
     OFFSETTEMP   VAR BYTE
     SIGN         var bit
     FLAG         VAR BYTE
     temp var byte
    '                         PINOUT 1 = IN; 0 = OUT
              '76543210
     TRISA  = %00000000
     TRISB  = %00000000
     TRISC  = %10010000
     TRISD  = %00001100
     TRISE  = %00000000
     ADCON1 = 7
    '                              ALIAS
     LED     VAR PORTB.7
     BMENOS  var PORTD.2
     BMAIS   var PORTD.3
     BMENU   VAR PORTC.4
     OUT     Var PORTC.2
     DQ      VAR PORTE.2
    '                              DEFINITIONS
     DEFINE LCD_DREG PORTB      ' LCD Data bits on PORTB
     DEFINE LCD_DBIT 0          ' PORTB starting address
     DEFINE LCD_RSREG PORTB     ' LCD RS bit on PORTB
     DEFINE LCD_RSBIT 4         ' LCD RS bit address
     DEFINE LCD_EREG PORTB      ' LCD E bit on PORTB
     DEFINE LCD_EBIT 5          ' LCD E bit address
     DEFINE LCD_BITS 4          ' LCD in 4-bit mode
     DEFINE LCD_LINES 2         ' LCD has 2 rows
     DEFINE LCD_COMMANDUS 2000  ' Set command delay time in us
     DEFINE LCD_DATAUS 50       ' Set data delay time in us
    '                             MAIN
    PAUSE 100
    INICIO:             '01234567890123456789
        Lcdout $fe, 1,  "    DS1820 Teste    "
        Lcdout $fe, $C0,"   HUGO  OLIVEIRA   "
        Pause 1000
    MAIN:
            if Bmenu = 0 then
               Pause 200
               goto  MENU
            gosub SENSOR
            IF SIGN=1 THEN
               Lcdout $fe, $C0, "Temp: -",DEC ABS (TEMPC/10), 223,"C           "
               Lcdout $fe, $C0, "Temp: ",DEC ABS (TEMPC/10), 223,"C            "
    Goto MAIN
    '                          BUTTON ROUTINE
    MENU:
     flag=1
     while flag <> 0
         if flag = 1 then
            Lcdout $fe, $1, "Menu 01-OffSet Temp."
            if OFFSETTEMP.7 = 0 THEN
                Lcdout $fe, $C0,"OffSet: ", DEC abs(OFFSETTEMP)
                Lcdout $fe, $C0,"OffSet: -", DEC abs(OFFSETTEMP)
            gosub PLUSBUTTON
            gosub MINUSBUTTON
        if Bmenu =0 then
            pause 200
            if flag = 1 then
                flag =0
                flag = flag + 1
     wend
    GOTO MAIN
    PLUSBUTTON:
        if Bmais = 0 then
            pause 200
            if flag = 1 then
                if OFFSETTEMP = 5 then
                    OFFSETTEMP = 5
                    OFFSETTEMP=OFFSETTEMP + 1
    MINUSBUTTON:
        if BMENOS = 0 then
            pause 200
            if flag = 1 then
                if OFFSETTEMP = 251 then
                    OFFSETTEMP = 251
                    OFFSETTEMP=OFFSETTEMP - 1
    '                          TEMPERATURE ROUTINE
    SENSOR:
        owout DQ,1,[$CC, $44]
        Pause 200
        owout DQ,1,[$CC, $BE]
        OWIn  DQ, 2, [TempC.byte0, TempC.byte1]
      temp=abs(OFFSETTEMP)
      IF OFFSETTEMP.7=1 then
          temp =(temp<<1)
          tempc = TEMPC-temp
          temp =(temp<<1)
          tempc = TEMPC+temp
        sign = tempc.15
        TempC = ABS(TempC)
        TempC =(TempC>>1)*10 + (TempC.0 * 5)
    In the aquisition and temperature conversion routine i change from this:
    SENSOR:
        Pause 200
        sign = tempc.15
        TempC = ABS(TempC)
    to this;
    SENSOR:
        Pause 200
          temp =(temp<<1)
          tempc = TEMPC-temp
          temp =(temp<<1)
          tempc = TEMPC+temp
        sign = tempc.15
        TempC = ABS(TempC)
    The new code and hex file is attached if some one want to give it a try.
    Thank you.
    Thanks and Regards;
    Gadelhas
