A slicker way to be constantly changing the duty cycle?
Results 1 to 15 of 15
    May 2007
    Default Re: A slicker way to be constantly changing the duty cycle?
    This contest http://www.picbasic.co.uk/forum/showthread.php?t=14652 contains some elements of what you are wanting to do.
    I did it using PWM and here is a video of 2 of those channels. The contest requires 4 independent, variable on-the-fly (blink-rate) channels.
    The timebase is 10uS so the PWM frequency 25KHz. The duty cycle of the upper trace is ramped from 0-100-0% - to give pulsating effect - at about 0.5Hz. The lower one is at 1.0Hz. The required blink rate should be continuously variable in the range of 0.5-8.0Hz on each of the 4 channels/LEDs for the contest.
    Mar 2009
    thanks rmteo...just seen your reply, I shall look at all tha tomorrow.
    ok, so I got too big for my boots, thought I'd go hardcore & try to get HPWM working with the PIC's regsiters (vs the HPWM command) - eeeugghh! (it was worth doing - just to remind myself that I'll always be the type who graps in the dark!)
    I've got it working, but only by directly loading the PWM 'period' registers directly like this (important bits in red)
    PR2= 63                               'THIS SETS THE PWM FREQUENCY (15.625KHZ @4MHZ)
    CCPTMRS0 = %11110011     'CCP Timer select register - select CCP2 USING TIMER2
    T2CON = %00000100           'TIMER2 ON 1:1 PRESCALER 1:1 POSTSCALER
    TRISC.3 = 0                         'Enable the CCP2 pin output driver by setting the bit
    temp:
    CCP2CON.4 = 1       ' these three lines set the duty cycle to be 255
    CCP2CON.5 = 1       ' these three lines set the duty cycle to be 255
    CCPR2L = 255         ' these three lines set the duty cycle to be 255 (2 MSBs ignored)
    CCP2CON.4 = 0       ' these three lines set the duty cycle to be 0
    CCP2CON.5 = 0       ' these three lines set the duty cycle to be 0
    CCPR2L = 0             'these three lines set the duty cycle to be 255 (2 MSBs ignored)
    goto temp
    the problem with that method (& it works - get a flashing LED at about 1 sec on, 1 sec off), is that setting the duty cycle is brainache. So I wanted to use the method discussed earlier with Henrik (where I map the bts to my easier to massage variable called "duty")...
    Duty var byte
    CCP2CON.4 = Duty.0       'Bit 0
    CCP2CON.5 = Duty.1       'Bit 1
    CCPR2L = Duty >> 2       'Bit 2-7
    temp:
    duty = 255         ' these three lines set the duty cycle to be 255 (2 MSBs ignored)
    duty = 0           'these three lines set the duty cycle to be 255 (2 MSBs ignored)
    goto temp
    Problem is now ...the LED he no flashee!!
    Anyone got a clue why I can't map the PWM 'period' bits to my variable called Duty? (or more to the point why it doesn't appear o work, whereas the top code does)
    Edit: Ok, think I've got a kludge, but this isn't working how I'd imagined...
    temp10:
    DUTY = 0
    DUTY = 1
    goto temp10
    in other words, I'm having to update the 'mapped' period register bits every time I change the duty variable? (I'd have thought Henrik's way of mapping them would mean if I change the contents of the duty variable then the mapped bits would automatically change too?)
    Aug 2010
    Maryland, USA
    Hi Hank, Let me take a stab at this for you.
    In your first example, you set the duty directly with constants. No surprizes there I don't think.
    In the second example, you are changing the variable named DUTY, but this is not associated with the ccp reg's, so they never get changed.
    In the third example, you are using a variable named DUTY to to assign values to the ccp reg's. This is the method I would use as it seem the easiest to me. It takes care of all the bit switching and all your code needs to do is change the value of DUTY.
    To combine the second and third example, make the ccp assigns in the third example a subroutine. Then in the second example, before each pause, call the sub. I think in this way it will seem like it does exactly what you want.
    To do what I think you are trying, I think you need to alais the ccp reg's. for example:
    CCP2CON.4    VAR Duty.0       'Bit 0
    CCP2CON.5    VAR Duty.1       'Bit 1
    CCPR2L.0    VAR Duty.2
    CCPR2L.1    VAR Duty.3
    CCPR2L.2    VAR Duty.4
    CCPR2L.3    VAR Duty.5
    CCPR2L.4    VAR Duty.6
    CCPR2L.5    VAR Duty.7
    Now I have NO idea if this will actually work, Try at you own risk
    -Bert
    Hi Hank, Bert,
    Bert already gave you the answer, but just to clarify. The code I showed you doesn't alias anything. It is code that needs to execute when ever you want to change the dutycycle - as you've discovered. The easiest way IMHO is to simply create a subroutine and GOSUB it when you want the dutycycle changed, like:
    Duty VAR BYTE
    i VAR Byte
    For i = 0 to 255              'Fade up
      Gosub SetIt
      Pause 2
    Next
    For i = 255 to 0 Step -1  'Fade down
      Gosub SetIt
      Pause 2
    Next
    Goto Main
    SetIt:
      CCP2CON.4 = Duty.0
      CCP2CON.5 = Duty.1
      CCPR2L = Duty >> 2
    Mar 2009
    Hi Guys.
    Firstly Bert....apologies I didn't post the full code (ironically, I thought for simplicity's sake)....further up my program, I had exactly as you'd outlined, namely...
    CCP2CON.4 =  duty.0
    CCP2CON.5 =  duty.1
    CCPR2L.0   =  duty.2
    CCPR2L.1   =  duty.3
    CCPR2L.2  =   duty.4
    CCPR2L.3  =   duty.5
    CCPR2L.4  =   duty.6
    CCPR2L.5  =   duty.7
    in fact I tried Henrik's simpler way first, but when that didn't work (ie period register didn't update as I thought they should), I mapped them longhand as above.
    Apologies for not showing the full picture....and many thanks for helping me out (again!)
    Henrik,
    Sometimes I get so wrapped up that I lose sight of the obvious (I had many things on the go yesterday ....ultimately cracking a long standing coding issue (yay) ....but while doing so, I think my brain got fogged).....yep, my variable 'Duty' is not 'tracked' in real time as it were, which means I do need to update the period setting bits bt y pointing at my variable everytime I wish to change the duty...so yes, your sub routine is the order of the day.
    Many, many thanks
    ....thanks heavens for forums like this with people so willing to help.
    Mar 2009
    Just as a footnote to this, going the longhand way with HPWM & setting the registers manually (vs copping out & using the easy HPWM command), has rescued back a fair bit of program space ...and my LEDS are fading a bit smoother too.
    So to sum up, this will get your HPWM running on CCP2 (Pin 7) on a 16f1824....
    DEFINE CCP2_REG PORTC     'route CCP2 output to PortC.3  Pin7 (16f1824)
    DEFINE CCP2_BIT 3         'route CCP2 ouput to PortC.3  Pin7 (16f1824)
    duty var byte
    CCP2CON    = %00001100   ' Turn HPWM on on CCP2
    TRISC.3   = 1            'Disable the CCP2 pin output driver by setting the bit
    CCPR2L.6 = 0             'I'm only using 8 bit PWM so clear the top two bits (these would be using for 9/10 bit HPWM)
    CCPR2L.7 = 0             'I'm only using 8 bit PWM so clear the top two bits (these would be using for 9/10 bit HPWM)
    PR2          = 63        'This sets the PWM period (frequency) to 15.625KHZ @4MHZ  (I hope so at least - I've  not scoped it!) and yields the full 255 bits of resolution
    CCPTMRS0 = %11110011     'This is the CCP Timer select register - these bits select 'CCP2 USING TIMER2'
    TRISC.3   = 0            'Enable the CCP2 pin output driver by clearing the bit
    duty = 255
    gosub Change_PWM
    duty = 0
    gosub Change_PWM
    goto Main
    Change_PWM:              'the following three lines for 8 bit PWM
    the above code will give you some LED blinkage (you can never have enough LED blinkage) to prove it's working ....all you have to do is change the variable "Duty" & then a Gosub to change the HPWM duty cycle.
    Many thanks to all who helped
    May 2007
    No all you have to do is get it to ramp 0>255>0 and you will be one step closer to your original intent - specifically wanting leds to fade niceley without any flickering.
