Hi Hank,
I usually cheat and use MisteE's PICMultiCalc tool to determine things like prescaler ratio and PWM resolution but I'll try to explain it. If nothing else as a learning exercise for myself....
The PWM period start when TMR2 is 0 and ends when TMR2 matches PR2. When you're running at 4MHz TMR2 "ticks" at 1MHz (with a prescaler of 1:1) so if you write 100 (or 99 actually because we're starting at 0) to PR2 you'll get a PWM period of 100us so the PWM frequency is 10kHz. Put 49 in PR2 and you'll get a PWM period of 50us (20Khz) and so on.
Now, you would think that if you put 99 in PR2 there are 100 "steps" to the "cycle"/period and that you therefor get 100 discrete dutycyles but this is not the case because TMR2 creates the 8 high order bits and the internal instruction clock creates the 2 low order bits of a 10bit timebase (alternatively 2 bits from the prescaler when using anything but 1:1).
What this means is that the number of discrete dutycyles ratios you get is basically (PR2+1)*4 so if you put 99 in PR2 (for a PWM frequency of 10kHz) you'll get (99+1)*4=400 "steps" which you'll have to have 9 bits to store. If you put 49 in PR2 the frequency will be 20kHz and the number of dutycycle ratios will be (49+1)*4=200 which fits nicely in a byte.
If you want to maximize the resolution while still keeping it inside a byte you could set PR2 to 63 which will give you a frequency of 15625Hz and a resolution of 8 full bits ( (63+1)*4=256 )
Well, I hope I've got this close to reallity (if not I hope someone will correct me) and that it makes at least a bit of sense.
PS. If "all" you're doing with the PWM output is fading LEDs why do you need it to be inaudible?
