Need advice with LCD 2x16
Results 1 to 10 of 10
    Dec 2008
    Ploiesti, ROMANIA
    Default Need advice with LCD 2x16
    Hi again ! For the start I want to thank you all for helping me so many times ! It's a great forum this one ! All my good thoughts for each of you !
    I made for one friend one thermometer, with two DS18B20 and LCD 2x16 display.
    I search all over the forum but I don't find the answer : how can I keep the value on display in the same position, even the number of characters change, from 3 (18,7) to 2 (9,4) ? I want to keep both temperatures value on same column. Hope the picture help to understand...
    Now I use this command for display :
    LcdOut $FE, $80, "IN  :  ", Sign1," ", DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, " ",223,"C "
    LcdOut $FE, $C0, "OUT :  ", Sign2," ", DEC (Temperature2 / 100), ".", DEC Temperature2 DIG 1, " ",223,"C "
    Thanks in advance !Name:  lcd_2x16.jpg
    Default Re: Need advice with LCD 2x16
    From the manual
    Note that there is a command to move the cursor to the beginning of the second line of a 2-line display. For most LCDs, the displayed characters and lines are not consecutive in display memory - there can be a break in between locations. For most 16x2 displays, the first line starts at $0 and the second line starts at $40. The command:
    LCDOUT $FE, $80 + 4
    sets the display to start writing characters at the forth position of the first line. 16x1 displays are usually formatted as 8x2 displays with a break between the memory locations for the first and second 8 characters. 4- line displays also have a mixed up memory map, as shown in the table above.
    So set the "static" text to start where you want it and let the VARs follow.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    I made this change :
    LcdOut $FE, $C0 + 9, DEC (Temperature2 / 100), ".", DEC Temperature2 DIG 1, " ",223,"C "
    and the position of first character of second temperature don't move. But I want to keep the position of the last character ; maintaining the alignment to the right !
    You could add a leading zero if the value is less than 10 or if the value is less than 10 the position is X else the position is Y.
    Dec 2008
    Ploiesti, ROMANIA
    ... if the value is less than 10 the position is X else the position is Y.
    I think this is the answer ! I will try.
    Dec 2008
    Ploiesti, ROMANIA
    I use this code :
     OWIn DQ2, 2, [temperature2.byte0, temperature2.byte1]
    If Temperature2.15 then
      Temperature2= ~Temperature2 +1
      Twist2 = 1
    Endif
    Dummy2 = 625 * Temperature2
    TempC2 = DIV32 10
    TempC2 = (Temperature2 & $7FF) >> 4
    Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
    Temperature2 = TempC2*100 + Float2
    If Twist2 then
      V2= 10000 - Temperature2
      Twist2 = 0
      V2= 10000 + Temperature2
    EndIf
    If V2 >= 10000 then
      Temperature2=V2-10000
      Temperature2=10000-V2
    EndIf
    How can I say "if temperature2 > 9.99 'C or temperature2 < -9.99 'C" ?
    Convert the temperature to an absolute value.
    From the manual
    4.17.4. ABS
    ABS returns the absolute value of a number. If a byte is greater than 127 (high bit set), ABS will return 256 - value. If a word is greater than 32767 (high bit set), ABS will return 65536 - value.
    B1 = ABS B0
    Then you are back to IF < 10.....Just remember your sign...
    Dec 2008
    Ploiesti, ROMANIA
    Default Yes !
    I have good results, based on this "$FE, $14 - Move cursor right one position" :
    if (temperature2/100) =>10 then
    LcdOut $FE, $c0, "OUT :  ", Sign2," ", DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, " ",223,"C "
    LcdOut $FE, $C0, "OUT :  ", Sign2," ", $14, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, " ",223,"C "
    Thanks !!!
    If you wanted to move over an extra character to maintain alignment, why not just add an extra blank after SIGN2?
    LcdOut $FE, $C0, "OUT : ", Sign2,"  ", DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, " ",223,"C "
    Moving the cursor can give misleading information unless you clear the display first. $C0 sets the cursor position to the beginning of the 2nd line, it does not erase what was written previously.
    Let's say it is displaying 25C and the reading changes to 7C. If you move over 1 position, the 2 will still be there, giving 27C.
    Last edited by Demon; - 26th April 2011 at 06:17. Reason: Cause the code alignment gets all messed up when I clicked POST
    Dec 2008
    Ploiesti, ROMANIA
    Thank you !
    I try my code in ISIS and work ok ; it' possible, in 'real life' to work bad...but I do not have -yet- the hardware.
    Please remove .txt from simulation file.
