Mcp 23017 and Pic 16f877
Results 1 to 17 of 17
    Apr 2011
    BELGIQUE
    Default Re: Mcp 23017 and Pic 16f877
    Hello Alain,
    I still have not found the solution.
    Here's a quick diagram as requested.Printing TEST MCP23017-sch.pdf
    Thank you
    Claudy
    Looks there's also a missing register named IOCON in the settings.
    Apr 2011
    BELGIQUE
    Hello everyone,
    Ok it works!
    Bit 7 of Port A and B of the MCP23017 must be 1 before the startup of the program.
    And in this case each power program is operating normally the first
    Here is the code added.
    i2cwrite sda,scl,$40,[iolata,128] 'Output Latch Reg
    i2cwrite sda,scl,$40,[iolatb,128] 'Output Latch Reg
    If you have comments please.
    Thank you
    Claudy
    rauloj's Avatar
    rauloj Guest
    Quote Originally Posted by CLAUDY View Post
    Thank you
    Claudy
    Hi Claudy!
    It's not OLATA/OLATB you are setting 1, but IOCON.
    After power-on BANK bit = 0 and IOCON's adr = 0A/0B not OLATA/OLATB's.
    After setting IOCON bit 7 to 1 you can use address mapping as described in datasheet table 1-5.
    R
