HPWM on 16F88
Results 1 to 8 of 8
Thread: HPWM on 16F88
    SWITZERLAND (french speaking)
    Default Re: HPWM on 16F88
    Try to set your fuse like this:
    @ DEVICE PIC16F88, CCPMX_OFF
    where:
    0 = "ON" CCP1 on RB3
    1 = "OFF" CCP1 on RB0
    You also need to set a register:
    CCP1CON = %00001100 'Select PWM Mode
    HTH
    Roger
    Default Use PWM instead
    Instead of using HPWM, try this:
    PWM PORTB.0,speed,1000
    You won't need to declare/define T2CON, CCP1CON, PR2 and CCPR1L.
    PS: I'm using MCS
    Roger
