HPWM on 16F88
Results 1 to 8 of 8
Thread: HPWM on 16F88
    Jan 2008
    Selm, Germany
    Default Re: HPWM on 16F88
    Hello Darrel,
    nice you took a look at my childish problem.
    The config files you mentioned were in the upper part of the program
    do I have to put them in the .inc file? Iīm confused.
    And i was so frustrated I wrote code that used Portb.0 as switch
    inside my simple program because I feared the chip was blown but it works.
    it is just: I canīt get portb.0 as HPWM output AND the normal LCDout application at once. The LCD is the reason I canīt switch the port. got the boards already.
    sream, howl, and so on
    SWITZERLAND (french speaking)
    Try to set your fuse like this:
    @ DEVICE PIC16F88, CCPMX_OFF
    where:
    0 = "ON" CCP1 on RB3
    1 = "OFF" CCP1 on RB0
    You also need to set a register:
    CCP1CON = %00001100 'Select PWM Mode
    HTH
    Roger
    Default Use PWM instead
    Instead of using HPWM, try this:
    PWM PORTB.0,speed,1000
    You won't need to declare/define T2CON, CCP1CON, PR2 and CCPR1L.
    PS: I'm using MCS
    Roger
