MicroCode Studio oddity...
Results 1 to 14 of 14
    Default Re: MicroCode Studio oddity...
    This is what I use from within MCSP:
    -P$target-device$ -F$hex-filename$ -E -M -B -L -V5
    And the exutable is called PK3Cmd.exe which I don't think is the same as the standalone programmer software for the PK3.
    The -V5 is said to specify the voltage output on the Vdd line by the PICKit3 so be careful if you're using a 3.3V PIC etc.
    Thanks Henrik, that did the trick.
    I also get the auto-correct oddity in MCSP since I updated (I had an old version).
    (system specs below)
