MicroCode Studio oddity...
Results 1 to 14 of 14
    Default Re: MicroCode Studio oddity...
    Yeap and I had some issues with windows ghosting, reported to Norm, but I suppose he is busy.
    I can't replicate the problem of ghosting however I am working on a new version of FL.
    It's built with the latest Delphi compiler and includes some options for windows 7.
    I'll send you a beta copy when it's ready.
    Norm
    Thanks Norm. I will be looking forward to.
    @ mtripoli: it is indeed very annoying when that happens. I learned my lesson and hit the Ctrl+S all the time. Almost annoyingly often .
    Yeah... I hit the save key pretty often myself...
    @Norm: I downloaded and am using your IDE; very impressive. I've been using it for about half an hour and it's been tooling right along.
    I'm using the PICKIT3 programmer. I saw the setup string for firing the programmer, but when it comes up I still have to load the uC and program manually (I'm using a 16F1946). Anyone got any ideas on getting this to program automatically? I think my device declaration is wrong as well; I still don't have the declaration format correct for using Microchips programmers (@ DEVICE HS_OSC,WDT_OFF,BOD_OFF,LVP_OFF,PROTECT_OFF) doesn't work...
    Are you using the stand alone software for Pickit3?
    If yes, it has the auto import hex and write button. Just click it to turn on the feature.
    Yes, I'm using the PICKIT3 software... and the "auto import". I'm referring to a way that the programmer starts and programs without having to hit the "auto import" button. I know that there is a command line version of the PICKIT2 available in which you can do this; I haven't looked yet for the same for the "3".
    This is what I use from within MCSP:
    -P$target-device$ -F$hex-filename$ -E -M -B -L -V5
    And the exutable is called PK3Cmd.exe which I don't think is the same as the standalone programmer software for the PK3.
    The -V5 is said to specify the voltage output on the Vdd line by the PICKit3 so be careful if you're using a 3.3V PIC etc.
    Thanks Henrik, that did the trick.
