How to set the internal CPU speed?
Results 1 to 13 of 13
    Default Re: How to set the internal CPU speed?
    If resonators that have built in capacitors are used, even if they are 4MHz use "HS".
    Hi Dave,
    I never heard about that one, where did you ferret out that little tidbit ?
    Is it because the resonators exhibit lower impedance, and thus require more power ? I seldom use the low freq resonators, but I will put that away in my memory bank for the future.
    Well...
    I have always used the 3 pin resonators with built in capacitors and way back when I knew less than I do now.....
    Making the transition from the Stamp, I was using a 20MHz with the 887, wanted to go with a little less power so I popped in a 4MHz and did not even think about changing the config. It worked fine.
    Then stuff like this from the data sheets
    When operating below 3V VDD, or when
    using certain ceramic resonators at any
    voltage
    , it may be necessary to use the
    HS mode or switch to a crystal oscillator.
    RTFDS,
    Still never saw that, probably never read beyond what I already knew inside the box. It makes perfect sense, esp. as it pertains to 3v operation. Anyway, thanks for pointing that out.
