How to set the internal CPU speed?
Results 1 to 13 of 13
    Mar 2011
    Los Angeles, California
    Default Re: How to set the internal CPU speed?
    Thanks Dave!
    Now it makes a lot more sense!
    I noticed you did not use "OSCCON=%01110000"?
    Second does anything change if you are using a 20 MHz Resonator?
    Just seems like you should be putting in a multipication factor some place?
    Thanks, Ed
    I used "OSCCON=%01110000" in the first code, the one for the internal setup. It is not needed when using the external.
    When using a 20MHz external the first config line will look like this
    @ __CONFIG _CONFIG1H, _HS_OSC_1H & _FSCM_OFF_1H & _RC_OSC_1H
    The HSPLL_OSC_1H is the multiplier. All this chip can do is multiply by four.
    Now you will want to try over-clocking. Water cooled PICs
    Mar 2011
    Thanks Dave!
    Very interesting! So if I understand correctly, a 20 MHz external crystal with your line of code (thank you for this) will give an internal CPU speed of 40 MHz? By the way I like your idea of a "water cooled" PIC!
    Just curious since I have been away from all this for so long, in the past when you programmed your PIC you would have to specify either XT or HS depending upon what frequency resonator you used. It appears this is now "built-in" with a default of XT? (__CONFIG _CONFIG1H, _XT_OSC_1H).
    It is correct to assume with HSPLL the multiplier is always X4?
    Best, Ed
    And then this
    DEFINE OSC 20
    "HSPLL" would try to make the running speed 80MHz... I have my doubts if it would work. I have heard some folks tell of these running at 64MHz (and they did not use water...) but the data sheet claims 40MHz is the limit....
    With this chip, yes.
    From the data sheet
    2. XT Crystal/Resonator
    3. HS High-Speed Crystal/Resonator
    Table 2-1 and table 2-2 are also worth looking at. 2-1 is for resonators without built in capacitors and 2-2 is for crystals. If resonators that have built in capacitors are used, even if they are 4MHz use "HS".
    Hi Dave,
    I never heard about that one, where did you ferret out that little tidbit ?
    Is it because the resonators exhibit lower impedance, and thus require more power ? I seldom use the low freq resonators, but I will put that away in my memory bank for the future.
    Well...
    I have always used the 3 pin resonators with built in capacitors and way back when I knew less than I do now.....
    Making the transition from the Stamp, I was using a 20MHz with the 887, wanted to go with a little less power so I popped in a 4MHz and did not even think about changing the config. It worked fine.
    Then stuff like this from the data sheets
    When operating below 3V VDD, or when
    using certain ceramic resonators at any
    voltage
    , it may be necessary to use the
    HS mode or switch to a crystal oscillator.
    RTFDS,
    Still never saw that, probably never read beyond what I already knew inside the box. It makes perfect sense, esp. as it pertains to 3v operation. Anyway, thanks for pointing that out.
