Need advice with LCD 2x16
Results 1 to 10 of 10
    Default Re: Need advice with LCD 2x16
    Convert the temperature to an absolute value.
    From the manual
    4.17.4. ABS
    ABS returns the absolute value of a number. If a byte is greater than 127 (high bit set), ABS will return 256 - value. If a word is greater than 32767 (high bit set), ABS will return 65536 - value.
    B1 = ABS B0
    Then you are back to IF < 10.....Just remember your sign...
    Dec 2008
    Ploiesti, ROMANIA
    Default Yes !
    I have good results, based on this "$FE, $14 - Move cursor right one position" :
    if (temperature2/100) =>10 then
    LcdOut $FE, $c0, "OUT :  ", Sign2," ", DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, " ",223,"C "
    LcdOut $FE, $C0, "OUT :  ", Sign2," ", $14, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, " ",223,"C "
    Thanks !!!
    If you wanted to move over an extra character to maintain alignment, why not just add an extra blank after SIGN2?
    LcdOut $FE, $C0, "OUT : ", Sign2,"  ", DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, " ",223,"C "
    Moving the cursor can give misleading information unless you clear the display first. $C0 sets the cursor position to the beginning of the 2nd line, it does not erase what was written previously.
    Let's say it is displaying 25C and the reading changes to 7C. If you move over 1 position, the 2 will still be there, giving 27C.
    Last edited by Demon; - 26th April 2011 at 06:17. Reason: Cause the code alignment gets all messed up when I clicked POST
    Dec 2008
    Ploiesti, ROMANIA
    Thank you !
    I try my code in ISIS and work ok ; it' possible, in 'real life' to work bad...but I do not have -yet- the hardware.
    Please remove .txt from simulation file.
