3 channel PWM with customize duty cycle
Results 1 to 40 of 57
    Default Re: 3 channel PWM with customize duty cycle
    yes, i remove the pause statement because i think adding it causing the pwm duty longer then the original pwm duty, hence changing my pwm pattern.
    can we actually pause below 1 ms since i know pause statement can only be use for minimum 1ms right??
    correct me if im wrong
    when you tries on the real physical PIC, do you enable the pause statement??
    i will try on real physical PIC later and feedback to you tmrw.
    photoelectirc
    The Pause statement won't effect the PWM since it's generated in hardware. If you have Pause 1 you'll basically get 5 periods of each dutycycle value.
    You can Pause with microsecond resolution by using PauseUs (again, it's in the green book....)
    When testing I used 300us and you can see the result in the attached screenshot. This is not a simulation, it's captured on real hardware.
