3 channel PWM with customize duty cycle
Results 1 to 40 of 57
    Default Re: 3 channel PWM with customize duty cycle
    hi,
    i stick with prescaler 4 and alrdy key in my dutycycle in my lookup using command lookup2 since it can support til 10bits wide.
    below is my complete coding for 1 channel PWM:
    DEFINE OSC 20
    duty1 VAR WORD ' Duty cycle value (CCPR1L:CCP1CON<5:4>)
    duty2 VAR WORD
    TRISC.2 = 0 ' Set PORTC.2 (CCP1) to output
    CCP1CON = %00001100 ' Set CCP1 to PWM
    T2CON = %00000101 ' Turn on Timer2, Prescale=4
    PR2 = 249 ' Set PR2 to get 5KHz out
    'Set up a loop for 45 iterations, Duty1 will count 0,1,2,3,4....44
    For duty1 = 0 TO 185
    'Go into the table AND retrieve the value pointed at by Duty1 AND put that value in Duty2
    LookUp2 duty1, [0,18,34,52,68,85,102,119,137,152,170,187,203,220,2 36,253,267,285,302,318,334,_
    350,367,382,397,413,429,443,459,474,489,504,518,53 3,547,562,575,589,603,616,630,_
    643,655,669,681,693,706,718,729,740,752,764,774,78 5,795,806,815,825,835,844,853,_
    861,870,879,887,895,901,909,916,923,929,935,941,94 6,952,957,962,967,971,974,978,_
    981,984,987,990,992,994,996,997,998,999,999,1000,9 99,999,998,997,997,996,994,992,_
    990,987,984,981,978,974,971,967,962,957,952,946,94 1,935,929,923,916,909,901,895,_
    887,879,870,861,853,844,835,825,815,806,795,785,77 4,764,752,740,729,718,706,693,_
    681,669,655,643,630,616,603,589,575,562,547,533,51 8,504,489,474,459,443,429,413,_
    397,382,367,350,334,318,302,285,267,253,220,203,18 7,170,152,137,119,102,85,68,_
    52,34,18,0],duty2
    'Duty2 now contains the value from the lookup table that Duty1 points at. First time thru the loop it's 0 second time it's 18 and so on.
    CCP1CON.4 = duty2.0 ' Setup 10-bit duty cycle as
    CCP1CON.5 = duty2.1 ' a 10-bit word
    CCPR1L = duty2 >> 2
    'Pause 1 'Use each dutycycle value 10ms before going to the next one.
    Next duty1
    GoTo Main 'And do it all over again
    i compile then use real pic simulator to check the PWM pattern.
    seem like the duty cycle only read up to value 253 in my lookup table and then keep generating same dutycyle.
    did i miss sumthing in my code??
    attached is my screen shot of the pwm pattern. at the red area pwm duty is correct but at the yellow area it starts to generate same duty and not looking up to the value in the lookup2 command.
    please help assist
    photoelectric
    I've tried it here, on a real physical PIC, and it works just fine.
    I see that you've removed the Pause statement I had in there. If you don't have a delay there it will run thru the different dutycycles much faster then the actual PWM frequency. It tries to update the dutycycle registers several times during each PWM period which obviously won't work properly.
    Your PWM frequency is 5kHz so if you really do want to see "all the steps" you must have atleast 1/5000=200us between updates. I measured the execution time of the loop to around 25us with a 20Mhz oscillator so you're basically trying to update the dutycycle 8 times every PWM period.....
    yes, i remove the pause statement because i think adding it causing the pwm duty longer then the original pwm duty, hence changing my pwm pattern.
    can we actually pause below 1 ms since i know pause statement can only be use for minimum 1ms right??
    correct me if im wrong
    when you tries on the real physical PIC, do you enable the pause statement??
    i will try on real physical PIC later and feedback to you tmrw.
    photoelectirc
    The Pause statement won't effect the PWM since it's generated in hardware. If you have Pause 1 you'll basically get 5 periods of each dutycycle value.
    You can Pause with microsecond resolution by using PauseUs (again, it's in the green book....)
    When testing I used 300us and you can see the result in the attached screenshot. This is not a simulation, it's captured on real hardware.
    hi, yes you are correct, i test it on real physical and it works fine.
    But i dint really understand on how you calculate the execution of my FOR NEXT loop. Can you explain a liltle bit detailed on that.
    below is the previous quote on how you calculate the execution time.
    I didn't calculate it, I measured it - as it says in the message ;-)
    I put a TOGGLE PortC.0 just before the NEXT statement a put the scope on the pin. I got a 20kHz square wave which, because the pin is toggled each time thru loop, means it executes roughly 40000 times per second. 1/40000=25us
    hi,
    thks for the explanation, now my pwm works fines.
    attached is my currently pwm pattern for ccp1 and ccp2.
    NOw, i want to shift the CH2 pwm about 1/3 of the duration of the CH1 pwm which is
    10.20ms/3 = 3.4ms
    so, i intend to put pause command at:
    Main1:
    'For duty1 = 0 TO 44
    LookUp2 duty1, [0,70,137,208,275,341,408,470,529,588,643,694,745,7 88,827,866,898,925,_
    953,968,984,996,1000,996,984,968,953,925,898,866,8 27,788,745,_
    694,643,588,529,470,408,341,275,208,137,70,0],duty2
    CCPR1L = duty2 >> 2
    Pause 4
    CCP3CON.4 = duty2.0
    CCP3CON.5 = duty2.1
    CCPR3L = duty2 >> 2
    PauseUs 210 'Use each dutycycle value 10ms before going to the next one.
    'Next duty1
    'PauseUs 100
    GoTo Main1
    but seem like ccp1 and ccp2 pwm duration increase above 10.20ms.
    SO, what should i adjuzt to make pwm CH2 shift 1/3 of the pwm CH1
    without increasing the duration?
    thks
    photoelectricName:  F0000TEK.JPG
Size:  117.5 KBName:  F0000TEK.JPG
    If you're trying to get the 120° phase shift you can't do that with a PAUSE. You have to remember that only the PWM is done by hardware, everything else, ie. the lookup and setting the dutycycle registers are done in software.
    If you put a Pause 4 in there the whole software loop will "hang" for 4ms and whatever the CCP module is outputting will keep getting output untill it gets updated again. The FOR-NEXT loop will NOT run while the pause statements executes.
    If you want 120° phase shift you could do that thru an offset into the loopup table. If the table is 45 entries you want entry 0, 14 and 29 the first time. Then you want 1, 15 and 30 and so on. I'd probably skip the FOR-NEXT loop and rewrite it to so that I'd have three counters, all counting from 0 to 44 but with an offset of 15 between them, these will then get the dutycycle from the table and assingn them to the proper CCPModule.
    Im still trying to understand your explaination.
    So i have to use count command?
    can you give me an example of code for me to refer to?
    photoelectric
