No, why would you do that? If you do Duty2 = Duty3 you assingn the value of Duty3 TO Duty2 and overwrites the value Duty2 got from the lookup table.
I don't know how to explain this in any other way. You want Duty2 to contain the value from the Lookuptable and that's what it does after the lookup command has executed.
'Set up a loop for 45 iterations, Duty1 will count 0,1,2,3,4....44
For DUTY1 = 0 TO 44
'Go into the table and retrieve the value pointed at by Duty1 and put that value in Duty2
LookUp DUTY1, 0,18,35,53,70,87,104,120,135,150,164,177,190,201,211,221,229,236,_
243,247,251,254,255,254,251,247,243,236,229,221,21 1,201,189,_
177,164,150,135,120,104,87,70,53,35,18,0],DUTY2
'Duty2 now contains the value from the lookup table that Duty1 points at. First time thru the loop it's 0 second time it's 18 and so on.
CCP1CON.4 = Duty2.0 ' Setup 10-bit duty cycle as
CCP1CON.5 = Duty2.1 ' a 10-bit word
CCPR1L = Duty2 >> 2
Pause 10          'Use each dutycycle value 10ms before going to the next one.
NEXT DUTY1
Goto Main         'And do it all over again
Perhaps I don't understand the problem you're having? Have you actually tried it?
