Reading Array values into variables
Results 1 to 20 of 20
    Feb 2005
    Bellevue
    Exclamation Reading Array values into variables
    This is probably easy, but I can't seem to figure it out.
    I have an array of 34 bytes collected via Serin2. I can see each of these. What I need to do tho is read several of them and convert them from the hex values they represent now to decimal.
    So imagine:
    SSMAX(23) contains 83
    SSMAX(34) contains 03
    These make up a temperature measurement.
    I need to reverse these so I get 03 83, then convert these to DECIMAL
    03 83 to Decimal should give me 899. There is an implied decimal between the 9's so I'd divide by 10. the result would be 89.9
    BUT.. I can't find a way to get the data out of the array to deal with it.
    Does anyone have any ideas about this?
    I was planning to read each character 0 - 3 - 8 - 3 in sequence via a loop and multiply the 0*4096+3*256+8*16+3*1... But I can't seem to get data ouf of the array..
    I can't seem to get the array values into variables to work on them either.
    Thanks - this is new stuff for me.
    Tom
    Wink
    Did you know the array starts at element 0?
    (suggestion from a newb)
    Smile
    Are you sure you are processing your array in the proper order?
    I am also converting, DATAIN VAR BYTE[5] to one byte.
    RESULT=DATAIN[0]+(DATAIN[1]*10)+(DATAIN[2]*100)+(DATAIN[3]*1000)+(DATAIN[4]*10000)
    I was just about to search for a post. Someone had told me lately how to do the conversion and I was going to doublecheck my formula.
    what about the following
    DEFINE BOOTLOADER_USED 1
    DEFINE OSC 20
        ' Lcd defines
        define LCD_DREG PORTB     ' Set data pin of LCD to
        define LCD_DBIT 0         ' PORTB.0-PORTB.3
        define LCD_RSREG PORTB    ' Set RS bit of LCD to
        define LCD_RSBIT 4        ' PORTB.4
        define LCD_EREG PORTB     ' Set E bit of LCD to
        define LCD_EBIT 5         ' PORTB.5
        DEFINE LCD_LINES 4        ' 4 Lines LCD
        define LCD_COMMANDUS 2000 ' Command delay time in uSec
        DEFINE LCD_DATAUS 100      ' Data delay time in uSec
    WholeDecimalNumber var word
    SSD4        var byte
    SSD3        var byte
    SSD2        var byte
    SSD1        var byte
    SSMAX       var byte [80]
    MSB         var byte
    LSB         var byte
    ssmax[34]=$03
    SSmax[23]=$83
    SSD4= (ssmax[34]>>4)
    SSD3= (ssmax[34] & $f)
    SSD2= (ssmax[23]>>4)
    SSD1= (ssmax[23] & $f)
    WholeDecimalNumber=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1
    lcdout $fe,1,"myval=",#wholedecimalnumber dig 3,_
           #wholedecimalnumber dig 2,#wholedecimalnumber dig 1,_
           ".",dec1 wholedecimalnumber
    here: goto here
    Feb 2005
    Bellevue
    Smile Thanks for the quick replies! Question about the math
    The 4th post includes this:
    It appears that somehow this is reading the digits out of the bytes, but I have never seen the notation before.
    & $f
    Do these somehow mean first digit and second digit?
    TG
    >>4 => shift byte 4 position to the right. so you keep only the 4 high bits
    & $F => Bitwise and with hex F. so you keep only the 4 low bits
    everything is in the PBP manual section 4.17
    It's no more difficult than copying data from a single variable to another.
    X VAR BYTE
    Y VAR BYTE
    X = 3
    Y = X
    You can state X = SSMAX(23), Y = SSMAX(34), etc,,.
    Since the resulting value will be a word, then use something like this;
    SSMAX(23) contains 83h
    SSMAX(34) contains 03h
    Result VAR WORD
    Result.LowByte = SSMAX(23) ' Place 83h into lowbyte
    Result.HighByte = SSMAX(34) ' Place 03h into highbyte
    HSEROUT [DEC Result] ' Print decimal value of 0383h = 899
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Bellevue
    Red face Array values into Variables - into ONE variable..
    Seems like I should be able to figure this out, but I can't ...
    I have an array that contains 24 bits which equate to an altitude in tenths of meters.
    alt[1]
    alt[2]
    alt[3]
    I need to 1) display this, and 2) convert from meters to feet, so I need to stuff all these into a single variable which represents actual meters as opposed to tenths of meters, then convert to feet....
    Any ideas out there? They way I am doing it now is not working. I am just reading these into alt1, alt2, alt2, and showing them as #alt1, #alt2, #alt3... I get 13130 which may be 131.30 meters,(which would be about right) but I am not sure. I am also not sure how to make this a single variable ..
    Thanks !
    Tom
    Red face
    I have no answer, but I do see an immediate problem.
    A byte contains 8 bits, a word contains 2 bytes; that's a total of 16 bits.
    There is a way to do 32 bit math, I saw a section in the manual. You work with 2 separate words or something, I didn't pay much attention.
    Page 33, 4.17.1 - Multiplication.
    Using * and **, / and //.
    Good luck!
    Feb 2005
    Bellevue
    Question
    Exactly the problem.. I have 3 bytes that need to be put into one variable.. this is a 24 bit container that relates a number - the altitude in tenths of meters..
    How to get this into ONE variable I can work with is the first issue..
    Tom
    Wink
    Hi, Tom
    Let's have another view of the problem ...
    You get an altitude measurement, ...but what is your sensor ??? and mostly what is its precision ???
    I do not know lots of altitude sensors seriously able to give 1 cm on a hundred meters ... 1/10 000 precision, you sure ??? ... !!!
    May be a little look here could reduce your number sizes ...and simplify you work.
    24 and 32 bits arithmetics can be downloded from Melabs site ... if you really want to keep "ghost" centimeters !!!
    Hi Tom,
    What ranges are we talking about? Are you interested in altitudes higher than 21501 feet? If not, you can treat your input as a word(skip top 8 bits) and do your calculations on that. If you need to go higher, things will get more complicated but still possible. Higher than 65535 feet will get nasty ....
    Do you really need 0.1m(0.3feet) resolution? Will 1m(3feet) enough?
    Another thing .... you need to know how your inputdata(24bits) is formatted. My guess(based on your information) is that you are located at about 1096 feet. I'm assuming that "alt[3]" contains the most significant byte, 0,13,13 would be 000D0D in hex which is 3341 in decimal. 3341 tenths of a metre is 334.1m which is 334.1*3.28084=1096 feet.
    /Ingvar
    Feb 2005
    Bellevue
    Thanks for the responses..
    The precision is only tenths of meters. I don't know *why* the data is stored in 24 bits, it just is - not under my control, I am only trying to read it.
    Regardless - the fundamental problem is that I have a 24 bit value stored in 3 bytes that I need to make into a variable I can do something with..... like read it digit by digit, and put a "." in the tenth's spot, and then multiply it by a factor to convert to feet..
    TG
    Smile
    Have a look to that thread :
    http://www.picbasic.co.uk/forum/showthread.php?t=1217
    here you have the solution to put your 24 bits into something usable ... just divide them as soon to reduce it to less than 16 bits ...
    and that's all !!!
    Question
    And the answers to my questions are ...... ? Can't help if i don't know.
    /Ingvar
    Feb 2005
    Bellevue
    Oh- yes, sorry.
    We are at about 300ft. Should be reading about 100meters or so. The GPS alt data 'wanders' so tenths of meters is a little silly, yes, but that is what is output.
    The full range would want to support over 100,000ft in altitude.
    TOm
    Post
    Ok, you're building a spaceship, 100000 ft is high. I'd love to see this baby fly
    First i think you need to look over your inputdata, methinks it's not properly extracted. I can't see any correlation between your data and 100(ish) metres, unless ofcourse it's already in tenths of ft(000D0Dhex=3341dec 3341*0,3048=1018.34 which would be close to your 100m).
    Are you getting the data from a NMEA sentence($GPGGA) or is it a binary protocol? If it's NMEA you need to know that the data is separated by "," characters, they're not at a fixed position in the string. Atleast not towards the end of the string. This makes it difficult to extract and convert the data.
    When you have your data properly extracted, the conversion would look something like this(pseudocode) ....
        R0.HIGHBYTE = 0        'Prepare system variables for DIV32
        R0.LOWBYTE = alt[2]
        R2.HIGHBYTE = alt[1]
        R2.LOWBYTE = alt[0]
        AltMetres = DIV32 10
        Alt10Ft = AltMetres ** 21501  '21501/65536=0.32808
        SEROUT blah..,blah..,["Altitude :",dec Alt10Ft, "0 ft",13,10]
    ..... you could increase the resolution when "alt[2]" = 0 ......
        AltMetres.HIGHBYTE = alt[1]
        AltMetres.LOWBYTE = alt[0]
        AltFt = AltMetres ** 21501  '21501/65536=0.32808
        SEROUT blah..,blah..,["Altitude :",dec AltFt, " ft",13,10]
    .... you could ofcourse combine them .....
    IF alt[2] = 0 THEN
        R0.LOWBYTE = alt[2]
        R2.LOWBYTE = alt[0]
    /Ingvar
    Feb 2005
    Bellevue
    Thanks much!!
    Apparently it is important for the system to report over 100k...
    The data is binary, not NMEA. The 3 bytes are the altitude, and it is in tenths of a meter. (binary value in tenths of meters)
    My challenge is that I have THREE bytes.. each with values that together equal the value I need.
    Value is sent in these 3 bytes as LSB first, then NMSB, then MSB.
    Does that help?
    TG
    Post
    The code i posted handles your THREE bytes, alt[0] to alt[2], when needed. Alt[0] = LSB, alt[2] = MSB. At high resolution(1ft) it will go to 21500ft, low res(10ft) will go to 215000ft.
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  2. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 23:13
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  4. Seeting array variables in For-Next loop
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 07:01
  5. Putting values into an array
    By Vince in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 07:22
