16f886 and LCDOUT
Results 1 to 10 of 10
    Apr 2011
    Default 16f886 and LCDOUT
    HI ALL. WONDERING IF ANYONE HAS EXPERIENCE WITH 16F886 AND LCD OUT. I'M USEING A LUMEX LCD PART NUMBER LCM S01602DTR/A.
    MY CODE IS..
    'Configuration Bits
    @ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    @ __config _CONFIG2, _WRT_OFF
    OSCCON = $71 'SET OSCILTOR TO INTERNAL 8 MHZ
    DEFINE OSC 8
    '_________________________________________________ ____________________________
    'INITIALIZE PORTS
    'PORT A
    ANSEL = 0 'PORT A DIGITAL
    TRISA = %11111111 'PORT A ALL INPUT
    'PORT B
    ANSELH = %00000000 'PORT B DIGITAL
    TRISB = %00000000 'PORT ALL OUTPUT
    IOCB.0 = 0
    CCP1CON = %00000000
    'PORT C OUTPUTS
    TRISC = %00001111 'PORTC 0-3 INPUT 4-7 OUTPUTS
    'SET LCD PARAMETERS
    DEFINE LCD_DREG PORTB 'SET LCD DATA PORT
    DEFINE LCD_DBIT 0 'SET STARTING LCD DATA BIT
    DEFINE LCD_RSREG PORTB 'SET LCD REGISTER SELECT PORT
    DEFINE LCD_RSBIT 4 'SET LCD REGISTER SELECT BIT
    DEFINE LCD_EREG PORTB 'SET LCD ENABLE PORT
    DEFINE LCD_EBIT 5 'SET LCD ENABLE BIT
    define LCD_BITS 4 'SET TO 4 BIT
    DEFINE LCD_LINES 2 'SET NUMBER OF LINES ON LCD
    DEFINE LCD_COMMANDUS 1500 'SET COMMAND DELAY TIME IN US
    DEFINE LCD_DATAUS 44 'SET DATA DELAY TIME IN US
    'DECLARE ALIAS'S
    LED VAR PORTC.4 'LED on a 330 High is on
    LCDOUT $FE,1
    AGAIN:
    LCDOUT $FE,1,"TO PLAYER"
    LCDOUT $FE,$C0, "FROM PLAYER"
    high led
    low led
    goto again
    I'M CONCERNED THAT I MAY HAVE MISSED A REGISTER SETUP ON PORT B.
    ANY INPUT WOULD BE APRECIATED.
    THANKS,
    BILL
    Default Re: 16f886 and LCDOUT
    Hi BLUEBILL,
    You might look at those comparators and SR latch settings , and sspcon. . .I don't know the power up state of them.
    EDIT: Ok looks like sspcon affects PortC, CM2CON0,CM2CON1, CM2CON2, CM1CON0, somewhere in there I think.
    Miami, Florida USA
    BlueBill,
    Do you see anything on the LCD? Are you using a contrast resistor? Also, I think you should change the line
    IOCB.0 = 0
    to
    IOCB = 0
    I don't know if it would make a difference, but you want to disable all the PORB On-Change-Interrupts bits instead of just one.
    Anonymous
    Apr 2011
    BlueBill,
    IOCB.0 = 0
    to
    IOCB = 0
    Hi Robert.
    The LCD is blank which leads me to think i'm not initializing it. I'm using a 20k variable contrast resistor. I made the change IOCB.0 =0 to IOCB = 0 with no change. I will keep experimenting and post my results.
    Thanks again.
    Miami, Florida USA
    Quote Originally Posted by BLUEBILL View Post
    Hi Robert.
    Thanks again.
    Hmmm, I haven't worked with these LCD displays in a while, but I think 20k is too high. The way I do it is by using a 10k pot and I play with it (change values from 0 to 10k) to find the optimum value. Give it a try and let us know....
    Anonymous
    Apr 2011
    Smile Re: 16f886 and LCDOUT
    Thanks Robert. It is my contrast setting. The LCD works and I'm a bit more educated regarding the special function registers of a 16f886. I did check the setting on an earlier date but had no idea that the supply voltage would be so low. 800mv on pin 3 displays fine. I didn't adjust that far down until your suggestion. Thanks again and thanks for everyones input.
    Apr 2011
    Hi BLUEBILL,
    Hi. I replied a couple times but I'm a bit of a novice when it comes to FORUMS.
    I reviewed the registers and even cleared all applicable registers but still no luck.
    I tried manualy initializing by seting portb outputs and strobing the E bit but no joy. Hope this reply works.
    "define LCD_BITS 4 'SET TO 4 BIT"
    "define" should be "DEFINE" all your others were uppercase.
    Manual states
    These definitions must be in all upper case. If not, the compiler may not recognize them. No error message will be produced for DEFINEs the compiler does not recognize
    Miami, Florida USA
    Quote Originally Posted by aerostar View Post
    Manual states
    Good catch!! Yes the DEFINE must be all in upper case as stated in the manual.
    Anonymous
    Apr 2011
    Manual states
    Sorry, Its cap in MicroCode Studio. It changed when I cut and pasted it.???
