Ran out of space need help reducing code size
Results 1 to 6 of 6
    Feb 2011
    Default Ran out of space need help reducing code size
    I dont have much time to do this project and i tried to program my chip the easy way(but very long). I cant do it this way because i my code size is to big. If there is any way of doing this a easier smaller way please let me know.
    I have a main loop for hours mins and seconds for chaning my time and then sub loops like 1s digits and 10s for the hour this takes way too much space.
    loopa is the counting loop
    loophour:
    if num0=0 then
    hour=0
    for i=0 to 20
            pause 1
        next i
     goto loophour1s
     if num1=0 then
     hour=1
     for i=0 to 20
            pause 1
        next i
     goto loophour10s
    if numstar=0 then
        for i=0 to 20
            pause 1
        next i
        goto loopa
    goto loophour10s
    loophours10s:
    if num0=0 then
    hour=10
    for i=0 to 20
            pause 1
        next i
        goto loopmins
    if num1=0 then
    hour=11
    for i=0 to 20
            pause 1
        next i
        goto loopmins
    if numstar=0 then
        for i=0 to 20
            pause 1
        next i
        goto loopa
    goto loophour10s
    May 2008
    Italy
    Default Re: Ran out of space need help reducing code size
    To start you can remove all the for/Next placing PAUSE =20. This is all I can see from your post.
    Al.
    I have not done much programming in a year or so, and I am getting rusty . . . but as I remember, If Then GoTo s use up a lot of resources, try substituting select case routines instead, and for your mainloop use while / wend. Please Anyone correct me if I am wrong.
    Miami, Florida USA
    Also, how are you declaring your variables? Are you declaring them as bytes or words? It makes a big difference what type of variables you use.
    Anonymous
    Sep 2005
    Campbell, CA
    Is there no way you could simply use a device with more FLASH?
    Charles Linquist
    Feb 2011
    THANKS!
    had my var as a word thats why it was taking up so much space.
