Bluetooth Module, SKKCA-21, Cytron
Results 1 to 4 of 4
Threaded View
    Apr 2011
    Default Bluetooth Module, SKKCA-21, Cytron
    I am using SKKCA-21, a Bluetooth Module From Cytron. I have read a thread at
    http://www.microchip.com/forums/m221431.aspx
    I have a favour to ask, what is missing in my PIC Basic Pro Coding below? My question is how do I establish serial communication between a PC and a micro controller?
    I am using PIC16F77A to connect to a PC via a bluetooth module but the hyperterminal does not displays anything. Basically, the coding should transfer ASCII character 0, 1, until 9 to the PC when a push button is pressed.
    Disclaimer:
    The assembly language and C language does not perform the same function as my coding.
    Details:
    The language used is PIC Basic Pro, Compiler: MicroCode Studio Version 4.0, Assembler: Microchip/mpasm suite, MPLAB IDE v8.66, Windows 7.
    INCLUDE "modedefs.bas" ' Serial communication mode definition file
    DEFINE OSC 20 ' Oscillator speed is set to 20MHz
    TRISB = %11111111
    TRISC = %10000000 ' RC.7 => USART RX pin set to input
    PortC = 0
    SPBRG = 10 ' Baud Rate = 115200
    ' Variable definition
    count01 VAR BYTE ' variable to store TXREG content
    TXSTA = %00100100 ' Enable transmit and asynchronous mode
    RCSTA = %10010000 ' Enable serial port and continuous receive
    mainloop:
    IF (PortB.7 = 1) THEN
    FOR count01 = 0 TO 9
    PAUSE 2000
    TXREG = count01 + $30 ' Transmit Data
    HIGH PortD.2
    PAUSE 2000
    LOW PortD.2
    Next
    GOTO mainloop
    This is the coding from the microchip forum:
    LIST p=16F628a
    #include
    __config 0x2118
    X1 equ 0x30
    X2 equ 0x31
    X3 equ 0x32
    org 0x0000
    start
    goto initialize
    org h'0004' ;interrupt vector location
    retfie
    ;INITIALIZATION ROUTINE *
    initialize
    ;initialize ports and registers
    movlw 0x07
    movwf CMCON ;turn comparators off
    bcf STATUS,RP0
    gie01 bcf INTCON,GIE ;turn gie off
    btfsc INTCON,GIE
    goto gie01
    clrf PIR1 ;clear peripheral flags
    clrf PORTA ;clear all i/o registers...
    clrf PORTB
    bsf STATUS,RP0
    movlw b'00011111'
    movwf TRISA
    movlw b'00000110' ; RB1 = RX input, RB2=TX output
    movwf TRISB
    clrf INTCON
    clrf PIE1 ; no interrupt
    ;uart specific initialization
    ;txsta=Transmit STAtus and control register.
    bcf TXSTA,TX9 ; <6> 0 select 8 bit mode
    bsf TXSTA,TXEN ; <5> 1 enable transmit function
    bcf TXSTA,SYNC ; <4> 0 asynchronous mode.
    bsf TXSTA,BRGH ; <2> 0 disable high baud rate generator !!!
    xtal_freq = d'4000000' ;crystal frequency in Hertz.
    baudrate = d'115200' ;desired baudrate.
    spbrg_value = (xtal_freq/(baudrate*d'16'))-1
    movlw spbrg_value ;set baud rate generator value
    movwf SPBRG
    bcf STATUS,RP0
    ;more uart specific initialization
    ;rcsta=ReCeive STAtus and control register
    bsf RCSTA,SPEN ; 7 spen 1=rx/tx set for serial uart mode
    bcf RCSTA,RX9 ; 6 rc8/9 0=8 bit mode
    bcf RCSTA,SREN ; 5 sren 0=don't care in uart mode
    bsf RCSTA,CREN ; 4 cren 1=enable constant reception
    bcf RCSTA,FERR ; 2 ferr input framing error bit. 1=error
    bcf RCSTA,RX9D ; 0 rx9d input (9th data bit). ignore.
    movf RCREG,w ;clear uart receiver
    movf RCREG,w
    movf RCREG,w
    movlw 0
    movwf TXREG ;send out dummy character
    ; to get transmit flag valid!
    ; main programme *
    main
    loop
    btfss PORTA, 2 ;test if input device is ringing
    call ON1
    goto loop
    ON1
    movlw 'A'
    call transmitw ;send W to the UART transmitter
    bsf PORTB, 6 ;turn on RB2
    call Delay ;this waits for a while!
    bcf PORTB, 6 ;turn off RB2
    call Delay
    goto loop
    ;* TRANSMIT Routines *
    transmitw
    btfss PIR1,TXIF
    goto transmitw ;wait for transmitter interrupt flag
    movwf TXREG ;load data to be sent...
    ;transmitted data is in W
    ;* Delay Routines *
    Delay movlw d'2'
    movwf X3
    B3 movlw d'255'
    movwf X2
    B2 movlw d'255'
    movwf X1
    B1 decfsz X1,f
    goto B1
    decfsz X2,f
    goto B2
    decfsz X3,f
    goto B3
    Anyone have materials for reference ? I am not proficient in assembly language.
    BTW, Cytron provided this coding in C for reference, a DIY project, PR6:
    C language:
    #include
    __CONFIG(0x3F32);
    #define seg PORTD // define 7 segment as PORTD
    unsigned char a;
    void init(void) // subroutine to initialize
    // SPBRG=0x0A; // set baud rate as 115200 baud
    SPBRG=0x81; // set baud rate as 9600 baud
    BRGH=1;
    TXEN=1;
    CREN=1;
    SPEN=1;
    TRISD = 0b00000000;
    seg = 0b00000000;
    void display(unsigned char c) // subrountine to display the text on the screen
    while (TXIF == 0);
    TXREG = c;
    unsigned char receive(void) // subrountine to receive text from PC
    while (RCIF == 0);
    a = RCREG;
    return a;
    void main(void)
    init();
    while(1) // wait for 'ok' to be entered
    a = receive();
    if (a == 'o')
    a = receive();
    if (a == 'k') break;
    display('C'); // change the text for different display
    display('y');
    display('t');
    display('r');
    display('o');
    display('n');
    display(0x0a);
    display(0x0d);
    display('P');
    display('r');
    display('e');
    display('s');
    display('s');
    display(0x20);
    display('a');
    display('n');
    display('y');
    display(0x20);
    display('n');
    display('u');
    display('m');
    display('b');
    display('e');
    display('r');
    seg = 1;
    while(1) // wait for number and display it on 7 segment
    a = receive();
    if (a=='1'||a=='2'||a=='3'||a=='4'||a=='5'||a=='6'||a =='7'||a=='8'||a=='9'||a=='0')
    seg = a-0x30;
