Hyper Terminal Displaying Random Characters [PIC to PC via UART]
Results 1 to 9 of 9
    Default Re: Hyper Terminal Displaying Random Characters [PIC to PC via UART]
    INCLUDE “modedefs.bas” ‘ Serial communication mode definition file
    Does nothing with the chip hardware serial port. Just takes up code space.
    BTw, i am using http://www.cytron.com.my/viewProduct...7nn82zcVu7Ut0=
    , a USB to UART Converter.
    But does it invert the signal?
    Hyper-terminal: I don't use it.
    RealTerm allows you the option of sending / receiving data either as RAW or ASCII.
    as for how do I . . . are you attempting to send to PIC or send to PC ? If issue is sending to PC put numbers inside quotes like "2468" and pic will send ascii, or precede numbers with DEC2468 and it will go RAW, or HEX9A4 for hex.
    As for Dave's (Mackracket) question, he is asking if the cytron thing inverts the serial data, as HSERin / out sends data TRUE with a pull up and PC likes INVERTED.
    May 2008
    Italy
    The OP needs to use a level converter as MAX 232 which also invert the signal.
    Cheers
    Al.
    May 2007
    How are you doing with LPCXpesso?
