Trying to resolving 6 Compiler Errors
Results 1 to 8 of 8
    Default Re: Trying to resolving 6 Compiler Errors
    Quote Originally Posted by Ramius View Post
    Hi All,
    I am working with code written by another person and being new there are complier errors I am not sure how to resolve. I did post the questions under another title and there have been no answers so I thought maybe I would try here.
    Line 62 has: high presspwr there is no pin defined as presspwr which pin should be used?
    Line 195 has: d[17] = temp2.byte0 There is no array named d and I have never defined an array
    Line 196 has: d[18] = temp2.byte1 '
    Line 133 has: high pgc there is no pin defined as pgc which pin should be used?
    Line 220 has: gosub shutdownmemory there is no sub-routine with this name
    Line 221 has: gosub lowestpower there is no sub-routine with this name either end
    My guess is these 2 lines should be deleted and a new line added that says gosub resetintersema so the program will continue to run without stopping?
    Thanks to any and all who are willing to help and comment.
    Best, Ed
    223.
    Hi Ed,
    as Alain stated, you are missing some code.
    pick you pins for the pin errors
    you NEED to Make the array, since you ARE using it
    You need to make the missing sub routines and have them do what they need to do.
    EDIT:
    I retract the above, you need to copy code that works,
    I think if you get this to compile you will see stack overflows due to failure of the original code to return from subroutines, the subs flow into one another and subs calling subs without returns
    Mar 2011
    Los Angeles, California
    Thanks Joe and you are right I just did not know what to choose. For some reason my cut and paste did not include this part:
    Include "Modedefs.bas"
    '********************* Declaired Pins **************************
    Clk var PortD.2
    Dout VAR PortD.3
    Din var PortD.0
    Sclk var PortC.3
    Mclk var PortC.1
    I do not believe the other subroutines are necessary as the hope is to have this run continuously. I have never done an array so I have no idea exactly how this is written. I will certainly look at the subs and returns and just trying to take this one step at a time.
    Best, Ed
    Here is a thread I started for array newbies, especially read the posts which ARE NOT mine.
    http://www.picbasic.co.uk/forum/showthread.php?t=8876
    The example in this thread was written prior to PBP ver2.6 and as such the word Loop must be changed to something like MainLoop
    or MyLoop as Loop is now a reserved word associated to DO.
    The funniest thing in this thread ...
    is to try to use READ and WRITE whith a pic that has NO EEPROM ...
    From what I've found to get " success 4304 bytes used " AND perfectly knowing it even can't run in real life ...
    I gently suggest you to check your project from A to Z before coming back here ...
    is to try to use READ and WRITE with a pic that has NO EEPROM ...
    Details, Details, Details . . . Joe says with a sheepish grin . . . I wasn't paying such close attention . . .
