writecode work on 18f26j11?
Results 1 to 3 of 3
    Default Re: writecode work on 18f26j11?
    The "Word Programming" mode is not supported.
    You would need to write 64 bytes at a time with WRITECODE.
    ERASECODE will erase 1024 bytes.
    If you use the assembly language code from the datasheet, you can write 1 word at a time.
    But you can still only erase blocks of 1024 bytes.
    EE12212's Avatar
    EE12212 Guest
    thanks for the information Darrel.
    on monday i will try the both ideas (assembly and 64bytes at a time).
