serial communication problem with PIC18F25K22
Results 1 to 4 of 4
Threaded View
    Sep 2005
    France
    Angry serial communication problem with PIC18F25K22
    HI,
    I have a problem with 2 18F25K22 running at 12x4=48 MHz
    @ 19200 Bauds
    The first one (named:Net-master) sends every 0.5sec "0?" + 0A from portc.4 to the second one (named: NetATT) portb.7, using hardware usart 2
    NetATT, then sends (with TX2 Hardware) how many bytes received, what bytes,how many times it received something and the answer of the question "?0", in this case "625WAYX".
    It works fine in the beginning but after a few transmission (time = 26 + 1 because 0 first) the counter of "how many times it received something" seems to have a problem and restart at 0
    It will work again for few transmissions and at time = 26 it start to freeze.
    (see attached file taken from my PICKIT serial analyser: PSA.TXT)
    NETATT:
    '*  Name    : netatt-test.pbp                                   *
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 28/02/2011                                        *
    Include "modedefs.bas"
    define OSC 48
    ' - Memorisation des données EEPROM à la programmation
    		' à partir de l'addresse 1
            EEPROM  1,[24,41,36,21,29,80]
            '       1, H, Y, T, E, M, _
            ' à partir de l'adresse 16
            '          17,18,19,20
            EEPROM 16,[87,65,89,88]
            '      16, W ,A ,Y, X
    DEFINE ADC_BITS  8     ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 7     ' ADC clock source  (Frc)
    DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
    ' configuration USART2 portb.6 (communication to net-master)
    RCSTA2 = $90 ' Enable serial port & continuous receive
    TXSTA2 = $20 ' Enable transmit, BRGH = 0
    SPBRG2 = 38  ' 19200 Baud @ 48MHz, 0,16%
    ' configuration USART1 (external communication with EM1206 TIBBO)
    RCSTA1 = $90 ' Enable serial port & continuous receive
    TXSTA1 = $20 ' Enable transmit, BRGH = 0
    SPBRG1 = 77 ' 9600 Baud @ 48MHz, 0,16%
    ANSELA = 0
    ANSELB = 0
    ANSELC = 16     'analogue sur portc.4
    TRISA = %10001111
    TRISB = %10000001
    TRISC = %10010000
    PORTA = 0
    PORTB = 0
    PORTC = 0
    led      var PORTA.5
    moins    var PORTA.0
    plus     VAR PORTA.1
    x        var byte
    ldcnt    var byte           'clignotement de la led
    ldcnt2   var word           'idem
    voie     var byte
    nv1      var byte
    nv2      var byte
    nv3      var byte
    nv4      var byte
    what     var byte
    way      var byte
    remote   var bit
    att      var word
    vmax     var WORD
    attn     var byte
    val      var byte
    GP2      VAR BYTE            ' GP variable
    BytesIn2 VAR BYTE[10]        ' Up to 10 bytes
    ByteCnt2 VAR BYTE            ' Index pointer
    EOM      CON 10              ' EOM = "End Of Msg" terminating character
    OERR2    VAR RCSTA2.1        ' Alias USART over-run bit
    CREN2    VAR RCSTA2.4        ' Alias USART continuous receive enable bit
    RCIF2    VAR PIR3.5   ' Alias USART received character interrupt flag bit
    RCIF1    VAR PIR1.5
    GP1      VAR BYTE            ' GP variable
    BytesIn1 VAR BYTE[80]        ' Up to 80 bytes
    ByteCnt1 VAR BYTE            ' Index pointer
    OERR1    VAR RCSTA1.1        ' Alias USART over-run bit
    CREN1    VAR RCSTA1.4        ' Alias USART continuous receive enable bit
    d1       var  byte
    d2       var  byte
    d3       var  byte
    num1     var  byte
    num2     var  byte
    num3     var  byte
    num4     var  byte
    num5     var  byte
    num6     var  byte
    tx       var  portc.3        'signale un chgt a envoyer
    pause 10
    clear
    'Détermine la valeur max de l'att et positionne au max
    if portb.0 = 0 then
    vmax = 935
    ldcnt = 200                    'led clignote à environ 1sec
    vmax = 625
    ldcnt = 100                    'led clignote à environ 1/2sec
    att = vmax
    gosub out                      'envoi vers l'atténuateur
    'Détermine la voie du PIC (0-3)
    ADCIn 16,way
    IF way < 30 then
    way = 48               'voie 0 pour 470R
    goto mainloop
    IF way < 60 then
    way = 49               'voie 1 pour 2K2
    goto mainloop
    IF way < 90 then
    way = 50               'voie 2 pour 3K9
    goto mainloop
    way = 51               'voie 3 pour 10K
    '**************** programme principal ***************************
    mainloop:
        IF PORTA.2 = 1 then      ' inter en remote ?
        remote = 1
        remote = 0
        IF RCIF2 then      'reception from master PIC ?
        gosub RX2
        goto mainloop
    '********* reception with USART2 (from netMaster PIC) ****
    RX2:
        IF RCIF2 THEN       ' If RCIF2=1 there's a new character in RCREG
        BytesIn2[ByteCnt2]=RCREG2 ' Yes. Then store character in array
        IF BytesIn2[ByteCnt2]=10 THEN OutMsg2 ' LF (0A)
        ByteCnt2=ByteCnt2+1 ' Increment element index pointer
        IF !OERR2 THEN RX2 ' If NOT over-run, then re-cycle
        CREN2 = 0           ' Yes. Over-run condition is present, so clear it
        CREN2 = 1           ' Re-enable & clear over-run condition
        HSEROUT2 ["Over-run reset",13,10]
    OutMsg2:
    HSEROUT2 [13,10,DEC ByteCnt2," received bytes",13,10]
    HSEROUT2 [STR BytesIn2\ByteCnt2,13,10] ' Show each character
        hserout2 ["time:",dec x,10]
        x = x + 1
    IF BytesIn2[0] = 63 and Bytesin2[1] = way THEN
        gosub sendata                                           '?voie
        gosub reset2
        goto mainloop
    hserout2 ["?"]
    gosub reset2
    goto mainloop
    reset2:
    FOR GP2=0 TO ByteCnt2 ' Clear array bytes 0 to ByteCnt
    BytesIn2[GP2]=0
    NEXT GP2
    ByteCnt2=0           ' Reset index pointer back to first element
    WHILE RCIF2          ' Trash any left over characters in RCREG buffer
    GP2=RCREG2           ' after EOM is received
    WEND
    ' Fixe l'atténuateur
    out:
            attn = att / 10	' max 935 ==> 93dB + positionnement du 0.5dB
            IF attn * 10 <> att then
            	HIGH PORTC.1		' 0.5 dB
            	LOW PORTC.1
            IF attn < 63 then         'conversion vers 0-128
                IF attn < 31 THEN
    			val = attn & 31
    			val = ((attn - 31) & 31) + 32
            val = ((attn - 62) & 31) + 96
            IF val.0 = 1 THEN       '1
            	HIGH PORTB.5
            	LOW PORTB.5
            IF val.1 = 1 THEN       '2
            	HIGH PORTB.2
            	LOW PORTB.2
            IF val.2 = 1 THEN       '4
            	HIGH PORTB.3
            	LOW PORTB.3
            IF val.3 = 1 THEN       '8
            	HIGH PORTC.0
            	LOW PORTC.0
            IF val.4 = 1 THEN       '16
            	HIGH PORTB.1
            	LOW PORTB.1
            IF val.5 = 1 THEN       '31
            	HIGH PORTC.2
            	LOW PORTC.2
            IF val.6 = 1 then       '2éme 31
                high PORTB.4
                low PORTB.4
    sendata:
        toggle led
        read 16,nv1      'nom 1ere lettre
        read 17,nv2      'nom 2éme lettre
        read 18,nv3      '....
        read 19,nv4      '....
        if att < 10 then
        hserout2 ["00",dec att,nv1,nv2,nv3,nv4,10]
        if att < 100 then
        hserout2 ["0",dec att,nv1,nv2,nv3,nv4,10]
        hserout2 [dec att,nv1,nv2,nv3,nv4,10]  'val de l'att + nom de voie
    NETMASTER:
    '*  Name    : net-master-test.pbp                               *
    DEFINE OSC 48
    ' configuration USART2 (communication avec FAV)
    SPBRG2 = 77  ' 9600 Baud @ 48MHz, 0,16%
    ' configuration USART1 (communication RS232 externe)
    ANSELA = 0   ' analog off
    ANSELB = 0   ' analog off
    ANSELC = 0   ' analog off
    TRISA = %00000100
    TRISB = %10001000
    TRISC = %10100100
    PORTA = 0
    PORTB = 0
    PORTC = 0
    d1       var byte
    d2       var byte
    d3       var byte
    c1       var byte
    c2       var byte
    c3       var byte
    n1       var byte
    n2       var byte
    n3       var byte
    n4       var byte
    c11      var byte
    c12      var byte
    c13      var byte
    n11      var byte
    n12      var byte
    n13      var byte
    n14      var byte
    c21      var byte
    c22      var byte
    c23      var byte
    n21      var byte
    n22      var byte
    n23      var byte
    n24      var byte
    c31      var byte
    c32      var byte
    c33      var byte
    n31      var byte
    n32      var byte
    n33      var byte
    n34      var byte
    dgt1     var byte
    dgt2     var byte
    dgt3     var byte
    voie     var byte
    led      var PORTA.5
    raffr    var byte            ' raffraichissement
    value    var byte
    remote   var bit
    x        var byte
    BytesIn2 VAR BYTE[80]        ' Up to 80 bytes
    RCIF1    VAR PIR1.5
    depart:
    clear
    high led
    portc.4 = 1    ' serial to netatt
    PAUSE 1000
    ' demande la position au démarrage
    position:
    portc.4 = 1
    serout2 PORTC.4,32,["?0",10]
    toggle led
    goto position
    I can't use other than serout2 for this one because all usart ports are also used for other application.
    What is wrong ?
    Herve
