I had a similar issue several years ago with a 1307. I can't explain exactly what the problem was, but putting a 1uF very low-leakage cap across the battery solved the problem. An added benefit was that - if you were quick, you could change the battery without clearing the clock. The chip will run on the capacitor alone for 10-20 seconds. The cap has to be low-leakage, otherwise it will drain the battery.
