Switch sensor vs. switch PIC pin
Results 1 to 11 of 11
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Switch sensor vs. switch PIC pin
    So...This is correct ?
    If portA.7= 1 then
    valoare=temperature
    semn=sign
    valoare=temperature2
    semn=sign2
    Endif
    Gosub Selectie
    Gosub Display				' B for Common CATOD;without B for Common ANOD
    Goto Main
    Selectie :
    IF semn ="-" then
        DIGIT_3="-"
        DIGIT_3=" "
    IF valoare DIG 2 = 0 THEN
        DIGIT_2 = " "
        DIGIT_2 = valoare dig 2
        DIGIT_1 = valoare dig 1
        DIGIT_0 = valoare dig 0
    Display:					' For Common ANOD
    for i=0 to 4
        TEMP = DIGIT_3 : gosub segments
        COMMON_3 = 1 : PAUSE 1 : COMMON_3 = 0
        TEMP = DIGIT_2 : GOSUB segments
        COMMON_2 = 1 : PAUSE 1 : COMMON_2 = 0
        TEMP = DIGIT_1 : GOSUB segments
        COMMON_1 = 1 : DP = 0 : PAUSE 1 : COMMON_1 = 0 : DP = 1
        TEMP = DIGIT_0 : GOSUB segments
        COMMON_0 = 1 : PAUSE 1 : COMMON_0 = 0
    next i
    Thanks for support !Name:  ttt.jpg
    Dec 2008
    Ploiesti, ROMANIA
    One of my DS18B20 it's about 4 meters from PIC. What is the smaller value of resistor used for this sensor ? Can I try with 1k ? Thanks !
    Sep 2009
    I have used 15m cable and pull up resistor 680 ohms. Resistor value depends greatly on the capacity of cable. And the capacity of the cable depends on the length.
    Dec 2008
    Ploiesti, ROMANIA
    With 5 meters of cable from PIC to DS18B20, no need to decrease value of R (still 4k7). Thanks for support !
    Dec 2008
    Ploiesti, ROMANIA
    ...but, in some cases, I decrease the value to 3k9...for the same lenght of cables !
