Blowing up PICs left right and center
Results 1 to 10 of 10
    Bombay, India
    Default Re: Blowing up PICs left right and center
    George,
    I'm not sure if I can be of any help since I've never faced such a problem. However, have you tried calibrating your pickit3? I do not have a pk3 but, in the pk2 there is a calibrate function where you can set up the voltages accurately. It is under Tools->Calibrate VDD and set unit id on the pickit2 software.
    Maybe the VIHH needed for programming the part is off?
    Best
    New Zealand
    Thanks for that, just this very minute got it sussed, so hopefully this will help someone else out facing the same problem. BTW is appears PICkit 3 does not have the same calibration function as #2 - but will fairly accurately provide feedback of the voltage.
    The issue resolves itself on both of my programmers if I force the programmer to hold the device in reset.
    I did a conversion to a PIC16F88 to see if it was just the 628 playing up, however the 16F88 did the same thing so it must be something to do with my CONFIG system setup or hardware that's a bit quirky. Looking over the net there are many folks that have had the same problem, but none of the solutions I saw suggested to hold the pic into reset.
    Hallelujah!!!
    Apr 2011
    Happy to hear of your solution to the problem.
    Have you retried the 'dud' PICs to see if they are resurrected using this technique?
    New Zealand
    Cool Re: Blowing up PICs left right and center
    yes, have managed to erase the 'dud' chips, there is a technique - like plug them in, activate hold on reset, unplug then plug in again and erase twice - but it works at least!
