Blowing up PICs left right and center
Results 1 to 10 of 10
    New Zealand
    Default Blowing up PICs left right and center
    I've always found PICs to be rather hardy creatures until last week anyrate. In that time I've managed to blow up eight PIC16f628A chips and I have no idea what the problem is.
    I have a PICKit 3 and have wired up for ICSP, if I put a brand new chip in, it reads and recognizes it fine, I can program it without a problem, and it seems to do what it was programmed to do without much hassle, however - when I reprogram it that's where the problem starts, it will not recognize the chip "unexpected value returned" although it says it has cleared the chip, when I click on erase chip it it doesnt, and it fails when it tries to reprogram. Was getting really expensive over the weekend where the only store open was Jaycar and they are $15.90 each!!!
    The basics of the board are as follows PORTB.3 is being used as a PWM port at 20kHz and I'm driving directly (not through a resistor) to an AND gate HEF4081BP,
    PORTB.5 is toggling on and off and driving both to the AND gate, and also directly to the gate of an inverting buffer HEF4049BP.
    PORTA.0-A.3 are wired to a DIP switch which are each pulled low with a 10K resistor and switched high to VDD. (should I be switching via a 1k resistor??)
    The OSC pins are hooked upto a 20MHz crystal with two 15pF load caps to ground.
    The supply has a 0.1uF ceramic across the PIC, with another 0.1 on another part with a 4.7uF and a 47uF further down, it also has a 5.1V zener across the supply rail to protect against over voltage.
    The supply for running the circuit at this stage is solely coming from the PICKit3.
    I've set the PICKit supply voltage to 5.000V
    Has anyone had similar experiences? Any thoughts would be appreciated as I think I'm going to have to reprogram several more times and want to keep chip waste to a minimum - plus, its really bad form!
    Thanks guys - and girl
    New Zealand
    Default Re: Blowing up PICs left right and center
    It appears it's my PICKit 3??? I've built another board up that basically just has a crystal, LED and ICSP port does exactly the same thing on there too - so at this stage I'm 11 PICs down and growing fast! It's not something silly like code protect off not being specified in the config is it? Here is my config line:
    @ __config _HS_OSC & _MCLRE_OFF & _BODEN_OFF & _WDT_ON & _PWRTE_ON & _LVP_OFF
    George , Have you scanned the forum yet? I seem to remember about 2 years or so ago there was a thread about just such a problem. That's all I can remenber.....
    New Zealand
    Thanks Dave,
    I've had a good hunt, it seems that perhaps they are not blowing up and just code protected and my programmer just cant deal with or erase them. I was going to try at 5.5V and see if that helped, however I've tried to upload new firmware into my PICkit3 but that seems to have stuffed me up completely, the MPASM program is just hanging on 'connecting' and now my PICkit is unusable, I've just downloaded the latest MPASM suite but it still wont work - this project is getting more expensive than I'd ever hoped!
    New Zealand
    Managed to get my PICkit 3 reprogrammed with new firmware - my USB port didnt have enough supply to power the unit while upgrading firmware - used another port and worked a treat.
    However I've tried now programming with out code protect so specified _CP_OFF, same deal - identified device fine, programmed it, device works as programmed however I still cannot erase it etc - i just get this:
    Erasing...
    Erase device complete
    Blank Checking...
    The following memory regions failed blank check:
    Program Memory
    Address: 00000000 Expected Value: 00003fff Received Value: 00000000
    Blank check failed
    then if I try to reprogram it, I get this:
    Programming...
    The following memory regions failed to program correctly:
    Program Memory
    Address: 00000000 Expected Value: 00002860 Received Value: 00000000
    Programming failed
    If I shut the MPASM down then restart and plug in my micro I'll get:
    Target Device ID (00000000) does not match expected Device ID (00001060)
    New Zealand
    Angry Re: Blowing up PICs left right and center
    Ok, I've had a good look around the internet and have found many people have had experiences similar to mine when using PIC16F628A, some people have found a cure that works for them but nothing at this stage seems to work for me. Neither my PICkit 3 nor ETT programmer will recognize the PICs after they've been programmed, neither will they do anything to them - ie erase. I've tested the VPP while erasing and it runs up to 13.4 volts four times for a period of about 20ms.
    I've turned code protect off, i've turned MCLR on, have tried different programming voltages but now I just have 15 PIC16F628 chips that I cannot write to.
    It's getting so frustrating, if not for the cost of the components, but I've spent four whole days on it so far and gotten no where. I think it's likely to all go in the bin soon.
