I have been reading a good example of somewhat what I need (requires modifications) at this page: http://home.citycable.ch/flotulopex/...I_Frames_e.htm
Few questions have arisen in my mind about this code:
1) Why in this code IRM_OUT is an output but being used as an input?
2) It is declared that 'factor is a constant =0', then what does this routine do?Code:IRM_Out VAR PORTA.1 'IR RX Module VDD (OUT) TRISA = %00000000 'Set Input/Output IRM_Out = 1 'set port HIGH WHILE IRM_Out = 1 : WEND 'Wait here until a LOW signal is incoming FOR Ctr_A = 1 TO Max_Bit TMR1H = 0 'Reset Timer TMR1L = 0 'Reset Timer T1CON.0 = 1 'Start Timer WHILE IRM_Out = 0 : WEND 'stay here as long as input signal is LOW T1CON.0 = 0 'Stop Timer V_Tmr.LowByte = TMR1L ' \ V_Tmr.HighByte = TMR1H ' > Store data to LOW_BIT var L_Bit[Ctr_A] = V_Tmr ' / TMR1H = 0 'Reset Timer TMR1L = 0 'Reset Timer T1CON.0 = 1 'Start Timer WHILE IRM_Out = 1 : WEND 'stay here as long as input signal is HIGH T1CON.0 = 0 'Stop Timer V_Tmr.LowByte = TMR1L ' \ V_Tmr.HighByte = TMR1H ' > Store data to HIGH_BIT var H_Bit[Ctr_A] = V_Tmr ' / NEXT Ctr_A C_Led = 0 PAUSE 1000 'wait before continue
3) Also it will be much appreciated if someone can explain the following three routines as well, as this purpose is not clear to meCode:'______________________________________________________________ ' Factorise (time compensation due to BASIC operations latency) FOR Ctr_A = 1 TO Max_Bit IF L_Bit[Ctr_A] >= Factor THEN L_Bit[Ctr_A] = L_Bit[Ctr_A] + Factor IF H_Bit[Ctr_A] >= Factor THEN H_Bit[Ctr_A] = H_Bit[Ctr_A] + Factor NEXT Ctr_A
Code:'_______________________________________________ ' Rescale values (according to acquiring method???) FOR Ctr_A = 1 TO Max_Bit IF L_Bit[Ctr_A] > 0 THEN L_Bit[Ctr_A] = L_Bit[Ctr_A]/2 IF H_Bit[Ctr_A] > 0 THEN H_Bit[Ctr_A] = H_Bit[Ctr_A]/2 NEXT Ctr_A '______________________________________ ' Find the longest H_Bit = interval bit ' This to determine how many bits in pattern FOR Ctr_A = 1 TO Max_Bit IF H_Bit[Ctr_A] > Itv_Bit THEN Itv_Bit = (H_Bit[Ctr_A] + 100) 'store the highest H_Bit value in Itv_Bit Bit_Cnt = Ctr_A 'is the count of bits in the original pattern --- How can bit_cnt count the bits in the original pattern if it only enters this loop if H_Bit[Ctr_A] > Itv_Bit ENDIF NEXT Ctr_A '___________________________________________________ ' Replace all "after pattern" bits with value "zero" FOR Ctr_A = (Bit_Cnt + 1) TO Max_Bit L_Bit[Ctr_A] = 0 H_Bit[Ctr_A] = 0 NEXT Ctr_A
