PWM on pic16f1825 issues - 1.pbp v2.60c bug found, fix shown, 2.CCP2 on ALT pin probl
Results 1 to 6 of 6
    Feb 2011
    Default PWM on pic16f1825 issues - 1.pbp v2.60c bug found, fix shown, 2.CCP2 on ALT pin probl
    'LESSONS LEARNED
    ' 1. pbpbasic hpwm 2,64,1 works properly for the 16f1825 for ccp2 on pin7 RC3
    ' 2. must use TRISC.3 =0 to enable
    ' 3. needed to add definition for CCPTMRS0 in the MPASM P16F1825.inc
    ' 4. 16f1825/29 default cpu speed is 500Khz NOT 4Mhz
    This code works on pin 7 default for ccp2
    'COMPILED FOR PIC16F1825
    'for pic16f182x
    define ccp2_reg     PORTC
    define ccp2_bit     3       'ra5=ccp2 pin 2 VLED
    DEFINE HPWM2_TIMER 2
    dc   var   byte
    ANSELA = 0  ' disable A2D
    ANSELC = 0
        CM1CON0 = $0
        CM1CON1 = $0
        CM2CON0 = $0
        CM2CON1 = $0
     APFCON0.7 = 1            'assign  RX/DT to RA1 from RA5
     APFCON1.0 =  0           'assign ccp2 to 1= ra5 0=RC3
    ' APFCON1.0 =  1           'assign ccp2 to ra5 FROM RC3
    TRISC.3 = 0  ' pimary location for ccp2  pin7
    trisa.5 = 0  ' alt location for ccp2  pin2
    do
     for dc =255 to 1 step -1
                hpwm 2,dc,1000
    next dc
    loop
    Issue #1.
    compiled & got
    error    [113] c:pbp\pbppi14e.lib 2089: sysmbol not previously defined [CCPTMSR0]
    'FROM  MPASM PIC16F1825 processor include: p16F1825.inc
    'CCPTMRS          EQU  H'029E'
    'CCPTMRS0	      EQU  H'029E'  ; ADDED this and it worked just fine
    here's why
    'code from    c:pbp\pbppi14e.lib
    'hpwmch2
    line #2089
    '	movlb	CCPTMRS0 >> 7
    Issue #2: CCP2 does not out put to RA5
    'for pic16f182x
    define ccp2_reg     PORTA
    define ccp2_bit     5       'ra5=ccp2 pin 2 VLED
     APFCON1.0 =  1           'assign ccp2 to 1= ra5 0=RC3
     TRISA.5 =0                  ' the other way to enable the pwm output
                hpwm 2,dc,1000
    Any thoughts / fixes would be appreciated.
    Default Re: PWM on pic16f1825 issues - 1.pbp v2.60c bug found, fix shown, 2.CCP2 on ALT pin p
    The TRIS problem will be fixed by using CAPs in your defines.
    DEFINE CCP2_REG PORTC
    DEFINE CCP2_BIT 3
    MPASM is case sensitive.
    In your P16F1825.INC file just add CCPTMRS0 below CCPTMRS. It's OK to have more than 1 name defined for a file register.
    CCPTMRS EQU H'029E'
    Both just let the compiler know the file registers address.
    Not all PIC16F1xxx types have CCPTMRS0 and CCPTMRS1. The ones that don't normally have the timer select register defined as CCPTMRS.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2011
    Thanks Bruce,
    Will pay more attention to the caps issue.
    Any thoughts or considerations on the alternate location for CCP2?
    This did not work.
    Unless you're using the internal oscillator, you can't use RA5 as an output pin.
    -Bruce
    tech at rentron.com
    Feb 2011
    Yup, Figured that out the other night.
    It's them config words and assuming the compiler is doing what you want not what it was told to do. : )
    posted the details on the Microchip site.
    http://www.microchip.com/forums/m570397.aspx
    I knew I just need to set another bit, well actually it was 3 bits.
    You know what happens when you assUme.
    Lesson learned:
    1. don't assume the config words are set correctly shock
    2. rtfm some more. LoL
    RA5 is also OSCIN & CLKIN
    Since the thing ran, I assumed the FOSC was set correctly by the compiler.
    configword1 FOSC<2:0> was = 010 needed to be 100
    bit 2-0 FOSC<2:0>: Oscillator Selection bits
    111 =ECH: External Clock, High-Power mode (4-32MHz): device clock supplied to CLKIN pin
    110 =ECM: External Clock, Medium-Power mode (0.5-4MHz): device clock supplied to CLKIN pin
    101 =ECL: External Clock, Low-Power mode (0-0.5MHz): device clock supplied to CLKIN pin
    100 =INTOSC oscillator: I/O function on CLKIN pin
    011 =EXTRC oscillator: External RC circuit connected to CLKIN pin
    010 =HS oscillator: High-speed crystal/resonator connected between OSC1 and OSC2 pins
    001 =XT oscillator: Crystal/resonator connected between OSC1 and OSC2 pins
    000 =LP oscillator: Low-power crystal connected between OSC1 and OSC2 pins
    Okay, so now I can use the layout for my PCB without cutting.
    PWM on the Backlight led will now work. mr green
    Board specs:
    1.5" x 1" prototyping area with a V+ & GND bus on the ends
    RS-232 both 5v & full +/-12v via DB9
    Use the PICkIT "PROG" connector to also talk to it via rs232-TTL uses RA3 (in) and RA0 (out)
    LCD connectors for both styles of HD44780 Modules -- 1x16 & 2x8 on 0.1 centers
    Laid out for the 14pin PIC to control the LCD so the remaining pins can be used for fun things. Even the 14pin Pic has 2 pins open.
    Thanks for the help!
    pcb schematic, layout and 3d by KICAD [free]
    top view
    PCB (c)2011 Ofuzzy1.com
    ofuzzy1 , Your layout look pretty good but I notice one thing. You would have to use a cable for the ICSP because it is too close to the coaxial power connector. I always lay my boards out so that you can plug the PicKit2 into them directly. Just my preference I pupose. I less cable to loose....
