Hi Darrel
You're correct, I mispoke, 254 items in the table.
Thanks for looking.
Table below:
' The table below forms the basis for a variable frequency amplitude modulator, the envelope for which is
' generated from the 16F1827 on-board DAC and table below.
' This table contains the values for the dwell time between each DAC point
' of the envelope. It corresponds to A2D measurement (counts / 4) of the
' 5volt analog signal.
' Measurement = A2D counts / 4 (full range becomes 0 - 255)
' DacDwell = microseconds between DAC points
DwellTable:
lookup2 Measurement,[$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '0 - 7
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '8 - 15
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '16 - 23_
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '24 - 31
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '32 - 39
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '40 - 47
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '48 - 55
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '56 - 63
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '64 - 71
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '72 - 79
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '80 - 87
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '88 - 95
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '96 - 103
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '104 - 111
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '112 - 119
$0000,$0000,$0000,$0000,$0000,$0000,$0000,$0000,_ '120 - 127
$5161,$4c48,$47ce,$43d1,$403f,$3d09,$3a21,$377d,_ '128 - 135 1.5pps - 2.2pps
$3513,$32dd,$30d4,$2ef3,$2d36,$2b99,$2a18,$28b1,_ '136 - 143 2.3pps - 3.0pps
$2761,$2626,$24fe,$23e7,$22e1,$21e9,$20fe,$2020,_ '144 - 151 3.1pps - 3.8pps
$1f4d,$1e85,$1dc6,$1d10,$1c63,$1bbe,$1b20,$1a89,_ '152 - 159 3.9pps - 4.6pps
$19f9,$196e,$18ea,$186a,$17ef,$177a,$1708,$169b,_ '160 - 167 4.7pps - 5.4pps
$1632,$15cc,$156a,$150c,$14b1,$1458,$1403,$13b0,_ '168 - 175 5.5pps - 6.2pps
$1360,$1313,$12c8,$127f,$1238,$11f4,$11b1,$1170,_ '176 - 183 6.3pps - 7.0pps
$1131,$10f4,$10b9,$107f,$1047,$1010,$0fda,$0fa6,_ '184 - 191 7.1pps - 7.8pps
$0f74,$0f42,$0f12,$0ee3,$0000,$0000,$0000,$0000,_ '192 - 199 7.9pps - 8.2pps & 900Hz w/ no mod
$0000,$0000,$0000,$0000,$0000,$0000,$5161,$4c48,_ '200 - 207 900Hz w/no mod & 1.5pps - 1.6pps
$47ce,$43d1,$403f,$3d09,$3a21,$377d,$3513,$32dd,_ '208 - 215 1.7pps - 2.5pps
$30d4,$2ef3,$2d36,$2b99,$2a18,$28b1,$2761,$2626,_ '216 - 223 2.6pps - 3.3pps
$24fe,$23e7,$22e1,$21e9,$20fe,$2020,$1f4d,$1e85,_ '224 - 231 3.4pps - 4.1pps
$1dc6,$1d10,$1c63,$1bbe,$1b20,$1a89,$19f9,$196e,_ '232 - 239 4.2pps - 4.9pps
$18ea,$186a,$17ef,$177a,$1708,$169b,$1632,$15cc,_ '240 - 247 5.0pps - 5.7pps
$156a,$150c,$14b1,$1458,$1403,$13b0],dacdwell '248 - 253 5.8pps - 6.3pps
