Make an acceleration/deceleration ramp : any ideas?
Results 1 to 14 of 14
    Bombay, India
    Default Re: Make an acceleration/deceleration ramp : any ideas?
    You can delegate the timekeeping and ramping to the ISR. What you need to pass to it is the 'target' value and 'step size' Step Size could be +ve or -ve depending on which way you want it to move.
    the ISR could tick every millisec or maybe more depending on how fast you want to change the output.
    Sep 2005
    Campbell, CA
    I don't know how fast your ramp needs to be - but..
    I would use a timer interrupt - say 1 millisecond
    Multiply ramp time (in seconds) X 1000 to get the number of steps
    Take
    (endvalue - startvalue)/numberofsteps to get step size
    Initialize a counter with the start value and increment the step size in each interrupt.
    Depending on your needs, you may have to add some extra increments, because the step size will be an integer, and when multiplied by the number of steps may not exactly equal the
    end value.
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    Take
    end value.
    My maximum acceleration slope is incrementing a variable from 0 to 1200 in one second with a resolution of 1 (steps of 1).
    I've tried to "translate" your algorithm into this :
    'Variable init
    freq var word
    maxfreq var word
    minfreq var word
    stepnum var word
    stepsize var word
    time var word
    'Variables def
    minfreq=10
    maxfreq=1200
    time=10
    'Calculate steps
    stepnum=time*1000
    stepsize=(maxfreq-minfreq)/stepnum
    'Init counter
    freq=minfreq
    ' Counter
    freq=freq+stepsize
    'Update LCD
    lcdout $fe,$2,"Frequency: ",dec5 freq
    ' 1ms time base (simulates an interrupt)
    pause 1
    It is correct? Because the result of "stepsize" is a float in this case (0.119)...
    Sep 2005
    Campbell, CA
    According to my calculations -
    endval = 1200
    startval = 20
    endval - startval = 1180
    ramp time in milliseconds = 1000
    1180/1000 = 1.18 (so 1180/1000 = 1 = increment)
    1180//1000 = 180 (=remainder = fractional)
    fractional = 0
    oldfractional = 0
    frequency = 20 ; start value
    ISR:
    Frequency = frequency + increment ; increment the main part
    fractional = fractional + remainder ; Deal with the fractional part
    If fractional dig3 != oldfractional ; keep adding up the partial until we reach 1000
    oldfractional = fractional ; update so we can see the next change
    frequency = frequency + 1 ; add a count - since we broke 1000
    Endif
    This will increment by one every program loop and then add an extra count every 5 (or so) loops. I haven't tested the algorithm, but I believe it should deal properly with the 'wrap' when "fractional" overflows.
    Charles Linquist
    endval = 1200
    startval = 20
    fractional = 0
    oldfractional = 0
    ISR:
    Endif
    I've tested this :
    DEFINE OSC 32
    DEFINE LCD_DREG PORTC
    DEFINE LCD_EREG PORTD
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE ADC_BITS 10
    DEFINE LCD_COMMANDUS 10000
    DEFINE LCD_DATAUS 2000
    'Variable init
    freq var word
    maxfreq var word
    minfreq var word
    remain var word
    increm var word
    time var word
    potsense var word
    frac var word
    oldfrac var word
    delta var word
    'Variables def
    minfreq=10
    maxfreq=1200
    'Calculate steps
    delta=maxfreq-minfreq
    time=1000
    increm=delta/time
    remain=delta//time
    frac=0
    oldfrac=0
    freq=10
    ' Counter
    freq=freq+increm
    frac=frac+remain
    if frac dig 3 != oldfrac then
    oldfrac=frac
    freq=freq+1
    pause 1
    And it seems to work well, the "freq" value get incremented, and if I change the "time" variable, the "freq" value increments more or less quickly.
    But the "freq" increments without stopping, and this over 1200!
    Sep 2005
    Campbell, CA
    stop the incrementing or stop the interrupt when freq >= maxfreq
    Charles Linquist
    I've tried this on my real PIC with a potentiometer :
    DEFINE OSC 32
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE ADC_BITS 10
    ' ADC registers configuration
    ADCON0=%11101
    ADCON1=%10000
    ADCON2=%10000110
    ADCHS=%1010101
    ANSEL0=%11110000
    ' Variable init
    freq var word
    rfreq var word
    maxfreq var word
    minfreq var word
    dum6 var word
    dum7 var word
    accel var word
    decel var word
    frac var word
    oldfrac var word
    potsense var word
    ' Variables def
    maxfreq=1200
    minfreq=10
    accel=1000
    decel=1000
    ' Start freq
    freq=minfreq
    ' Start ADC conversion
    ADCON0.1=1
    WHILE ADCON0.1=1:WEND
    ' Store ADC results
    potsense.HighByte=ADRESH
    potsense.LowByte=ADRESL
    ' Convert pot result
    rfreq=(potsense<<6)**maxfreq
    ' Acceleration ramp
    if freq<rfreq then
    dum6=(rfreq-minfreq)/accel
    dum7=(rfreq-minfreq)//accel
    freq=freq+dum6
    frac=frac+dum7
    if frac dig 3<>oldfrac then oldfrac=frac:freq=freq+1
    ' Deceleration ramp
    if freq>rfreq then
    dum6=(maxfreq-rfreq)/decel
    dum7=(maxfreq-rfreq)//decel
    freq=freq-dum6
    frac=frac-dum7
    if frac dig 3<>oldfrac then oldfrac=frac:freq=freq-1
    ' Display results
    lcdout $fe,$c0,"Ref: ",dec5 rfreq
    pause 1
    And unfortunately the timing is not very accurate, it depends of the "maxfreq" variable defined. I can have a 1 or 2 seconds gap.
    And above 1000, the "accel"/"decel" values doesn't increase the time of the ramp.
