blink f675 Where I'm wrong?
Results 1 to 3 of 3
    Mike675's Avatar
    Mike675 Guest
    Default blink f675 Where I'm wrong?
    Hi everybody
    I'm lost and I'm out of ideas how to make it work.
    I start building a NiMH charger , but first of all I can't make blink a led.
    I have tried some other blink.hex (downloaded) to check my hardware and the led blinks.
    When I try to compile my *.asm file or those downloaded the resulting hex doesn't work - I supose my MPLAB settings are wrong, but where?
    This is my code
    list p=12f675 ; list directive to define processor
    #include <p12f675.inc> ; processor specific variable definitions
    errorlevel -302 ; suppress message 302 from list file
    __CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
    ;***** VARIABLE DEFINITIONS
    w_temp EQU 0x20 ; variable used for context saving
    status_temp EQU 0x21 ; variable used for context saving
    temp1 EQU 0x22
    temp2 EQU 0x23
    temp3 EQU 0x24
    led1 EQU 0x25
    ;************************************************* ******** ORG 0x000 ; processor reset vector
    goto main ; go to beginning of program
    ORG 0x004 ; interrupt vector location
    movwf w_temp ; save off current W register contents
    movf STATUS,w ; move status register into W register
    movwf status_temp ; save off contents of STATUS register
    ; isr code can go here or be located as a call subroutine elsewhere
    movf status_temp,w ; retrieve copy of STATUS register
    movwf STATUS ; restore pre-isr STATUS register contents
    swapf w_temp,f
    swapf w_temp,w ; restore pre-isr W register contents
    retfie ; return from interrupt
    ; these first 4 instructions are not required if the internal oscillator is not used
    main
    call 0x3FF ; retrieve factory calibration value
    bsf STATUS,RP0 ; set file register bank to 1
    movwf OSCCAL ; update register with factory cal value
    ; remaining code goes here
    bcf STATUS,RP0 ; Sel Bank 0
    movlw 0x07 ;
    movwf CMCON ; Turn off comparator
    bsf STATUS,RP0 ; Sel Bank 1
    clrf ANSEL ;Digital I/O
    movlw b'00001000' ; Specify GPIO port direction: all output, except GP3
    movwf TRISIO ; Set GPIO ports as xxOOIOOO
    bcf STATUS,RP0
    led btfsc GPIO,0
    goto offled
    onled bsf GPIO,0 ;to power led drive pin low
    goto temp
    offled bcf GPIO,0
    ;Timer
    temp movlw d'40' ;N=40
    movwf temp1
    tt3 movwf temp2 ;T~(N^3+N^2+N)*3
    tt2 movwf temp3 ;T~0.2sec
    tt1 decfsz temp3,1
    goto tt1
    decfsz temp2,1
    goto tt2
    decfsz temp1,1
    goto tt3
    goto led
    END ; directive 'end of program'
    led.hex generated (Ignore fuse 3F84 generate in my MPLAB and change it with 0184)
    :020000040000FA
    :020000000C28CA
    :040002000034003492
    :08000800A0000308A10021087B
    :100010008300A00E200E0900FF2383169000831298
    :100020000730990083169F01083085008312051858
    :100030001B2805141C2805102830A200A300A400CA
    :0E004000A40B2028A30B1F28A20B1E28172894
    :02400E00843FED
    :00000001FF
    In this thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=542
    I gave an example of Blinking an LED (with detailed comments) in Assembler.
    Melanie
    PS. Since the thread being exclusively Assembler does not belong in the PICBasic categories, it's been moved here.
    Mike675's Avatar
    Mike675 Guest
    Default Problem fixed
    Hi everybody,
    Finally I found where the problem was hidden.
    All my *.hex files are generated in a format which has at the end of the file a double 'retlw0'
    :0E01200083161E08A2000800851605120511A0 ;code in hex format
    :02012E0000349B ;0034 - retlw 00h
    :02013000003499 ;0034 - retlw 00h
    :02400E00843FED
    :00000001FF
    As you can see the last 4 lines are -my code
    -2lines of retlw 00h :02012E0000349B
    - config :02400E00843FED
    - end of file :00000001FF
    I checked the hex format at "http://www.cs.net/lucid/intel.htm"
    I don't know yet all the details but after I deleted the 2 lines of retlw 00 and burn the new code resulted in the PIC, it just worked.
    For those who build a code and have a successfully compiled *.hex file with no errors:
    -when the code is burned into the PIC and doesn't work maybe this unscientific fix may work.
    Mike
  1. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 21:30
  2. what on earth can I be doing wrong?
    By dmacq in forum General
    Last Post: - 10th February 2008, 22:13
  3. Can't get blink circuit to work :(
    By Techbuilder in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 14:00
  4. Can't get a 12F629 to blink a led
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 12:28
  5. I Just Can't Get it to Blink - 16F628
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 16:54
