12bit Power Supply
Results 1 to 20 of 20
    Default Re: 12bit Power Supply
    Interesting project.
    Are you using PID to control the output voltage?
    May 2007
    I'm guessing from the thread title that OP is using an external DAC - so PID is not needed. The MCU's I use have a built-in (dual-channel) 12-bit DAC and I have done something similar. The DAC output is scaled to 2V full scale. An op-amp (rail-to-rail) buffer with 6x gain and a simple linear output stage gives 0-12V output with 3mV resolution.
    If it is open loop, how is the output voltage regulated with the load?
    Feedback is required, isn't it?
    May 2007
    That is the purpose of the op-amp/buffer as in the figure below - the DAC provides the Vin. The gain is changed by altering the values of the feedback resistor pair R1, R2. Gain = (R1+R2)/R2.
    OK, it is the Vref voltage of the loop that is controlled. So the PIC is not in the output voltage loop.
    OK, it has some cons, but with a high resolution DAC it will work just fine.
    In fact I ordered a couple of MAX5541, 16bit DACs to play with the idea and build a digital controled Power Supply. One for the voltage and the other for he current.
    My dream I had from childhood...
    May 2007
    Using this method (MCU->Hi-Res DAC->Buffer/Amp), you can not only make the digitally controlled power supply of your childhood dreams but you can also turn it into a fully programmable unit that can generate all kinds of waveforms - very useful for test purposes. For example you can program it to generate stuff like sine, triangle, sawtooth, staircase and other custom waveforms. The trace below is a sine waveform generated by a 12-bit DAC. The timebase is 10uS/Div so the frequency is 40KHz.
    Yeap, that is the main idea.
    Not exactly to make a Power supply act like waveform generator but have it under some kind of profile control.
    E.g. for test of regulators steping the input voltage or slow starting power to load and see if it resets normaly etc.
