uart problem
Results 1 to 4 of 4
Thread: uart problem
    Mar 2011
    Default uart problem
    I am trying to make a battery powered device so power is of a premium.
    When i put the Pic 16f88 to sleep the uart pin RB5 stays hi which is drawing current from the supply as it is going into a RF transmitter that is turned off.
    How can i turn RB5 off when in sleep, i have tried TRISB = %11111111 to no avail
    Cheers
    Paul
    Default Re: uart problem
    If you need direct control of the TX pin your only option is to disable the hardware uart.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2011
    Thanks a lot.
    Paul
    Can't you just say
    PortB.5 = 0
    sleep
    PortB.5 = 1
    restart Uart etc if reqd
