Thanks Henrik
so to translate from
I would useCode:Dim MyVar As Byte At Buffer + &H01 Overlay
Thanks againCode:MyVar VAR Buffer.Byte$01
Thanks Henrik
No, in that case and as long as Buffer is a WORD (2bytes) or a LONG (4bytes) you can use:
MyVar VAR Buffer.Byte1
If Buffer is an array of BYTES ie.
Buffer VAR BYTE[128]
Then you need to index that array, like:
MyVar1 VAR Buffer[0]
MyVar2 VAR Buffer[1]
MyVar3 VAR Buffer[75]
And so on.
