Thanks Alain!
It is a great idea. This sensor is to measure the depth for a radio controlled submarine. It is one of a group of "sensors" that will be progammed into one big PIC. There is a tachometer on the port and starboard motors with temperature sensors, control for a sound module, a compass, internal flooding alarm, battery voltage and current draw, missile and torpedo status, and speed. Everything is to feed an on screen display as a overlay on the video from a periscope camera. The compass was my first project and turned out to be extremely accurate (.1 degrees). If you are interested, the compass is at http://www.robsonco.com/Dinsmore/Untitled_5.html.
Best, Ed
From my experience when you start operating towards the lower limits of a device it will tend to become "spritual" (technical term)
where sometimes it will work and sometimes it won't! A company called "Analog Devices" makes an IC called the ADG3304 which has one side that you give it your 3.3 volts and the other side the 5.0 volts. Another company called "Technological Arts" makes a model AD325V14 which takes this tiny IC and puts it on a board so it will plug in to a standard 14 pin DIP socket. The device has 4 bi-directional channels and they have other versions for upto 8 channels as well as a 4 channel open drain version. I hope this is useful to others.
