16f54 stops running with RC OSC
Results 1 to 8 of 8
Threaded View
  1. #2
    Default Re: 16f54 stops running with RC OSC
    If that is a copy paste then it is likely the problem.
    should be @spaceTwoUnderscoresConfig like so . . .
    @ __config_RC_OSC
    And it is only going to work if you have commented out the default config in the p16F54.inc file in the PBP root directory, or you can change the default to this and leave it out of your source code And this config is for MPASM assembler not PB.
    Then set your OSC speed with the define, This get's the pic peripherals all on the same page as to timing, how long is a pause or pauseus . . .
    define OSC 4
    BTW the things you define are supposed to be (MUST) be in uppercase letters so OSC is good, osc is not.
