16F777 at 115200 baud
Results 1 to 10 of 10
    Aug 2005
    NC, USA
    Unhappy Re: 16F777 at 115200 baud
    this is what i come up with the varrious values to set the baud value
    No Parity, True Parity, True No Parity, Inverted Parity, Inverted
    115200 -11 8181 16373 24565
    I have tried all the values, except -11, which is what i need I am pretty sure...
    HSEROUT ["!M ", dec Motor_Val_R," ", dec Motor_Val_L, 13]'command motors ***THIS WORKS!!!!!!
    SEROUT2 portB.4, 23, ["!M ", dec Motor_Val_R," ", dec Motor_Val_L, 13]'command motors, this does not....
    I am snooping the packages, there is nothing when i run the serout2 line. the hserout2 works fine and looks fine on hyperterminal with the snooping...
    Any ideas, Unfortunatly I can not change the baud rate of the motor controller to something slower... Have to get 115k working and i can't use the hardware port for the final configuration...
    Sep 2005
    Campbell, CA
    Default Re: 16F777 at 115200 baud
    You will not be able to run serout at more than about 19.2K baud with a 20Mhz Xtal
    But, you MAY be able use DEBUGOUT at that rate. I have done it at 40Mhz on an 18F part.
    Charles Linquist
    Default PIC at 115200 baud
    I routinely run 115,200 on a PIC18F4620 at 20 MHz.
    Works a treat. I always set char_pacing to 20 or more to give some more time for the receiving side to process the character.
    HTH
    BrianT
    The forumula they have in the maual is (1000000/baud)-20, which results in -11.
    As Al pointed out (but didn't really spell out) the 1000000 comes from Fosc/4 and since you're running at 20MHz the formula becomes (5000000/115200) - 20 = 23. I don't know if 115200 "should" work at 20MHz but if you can't get it going try DEBUG instead.
    Aug 2005
    NC, USA
    Thanks for all the help. I understand fosc/4, but i am not sure Serout2 or serin2 uses that. I define the osc speed up top. I have to use 10000000 to get 19200 or 38400 to work with no issue. the debug may work for outgoing, but eventually i will need incoming... I am currently laying out another board with a 2 UART chip since hserin and hserout work fine at 115k and a 20mhz osc, but i would really prefer to use my existing chip.
    -Charlie
    OK, you're probably correct then, sounds a bit strange though.... Anyway, if DEBUG does indeed work for the output then DEBUGIN will most likely work for the input - as long as you don't need to change pin or baudrate at runtime.
    Sep 2005
    Campbell, CA
    Debug is much more "light weight", since the parameters are calculated at compile time, not every time the routine is called.
    It works fast in both directions.
    Charles Linquist
