I originally installed version 8.63, uninstalled it and installed version 8.60. still with same problem. here is my PBPMPLAB.BAT file.. same as yours:
Code:@echo off setlocal enabledelayedexpansion :: This file is intended to be run from MPLAB for compilation :: using the PICBASIC PRO Compiler. PBPMPLAB.BAT should be :: located in the PBP install folder (default C:\PBP). :: Set for default location on 32-bit systems SET MPASMWIN_PATH=C:\Program Files\Microchip\MPASM Suite :: If that doesn't work, set for default location on 64-bit systems IF NOT EXIST "!MPASMWIN_PATH!\MPASMWIN.EXE" ( SET MPASMWIN_PATH=C:\Program Files ^(x86^)\Microchip\MPASM Suite ) ::*************** User modifications here *************************** :: In order for PBP to launch the MPASMWIN Assembler, the :: location of MPASMWIN.EXE will be appended to the existing :: PATH environment variable. If MPASMWIN is not located in :: one of the default folders above, uncomment and change the :: following line to reflect the true location: rem SET MPASMWIN_PATH=C:\Program Files ^(x86^)\Microchip\MPASM Suite ::******************************************************************* :: Code below this point should not need to be modified. IF NOT EXIST "!MPASMWIN_PATH!\MPASMWIN.EXE" ( echo MPASMWIN.EXE could not be found at: echo !MPASMWIN_PATH! echo In order for PBP to function from MPLAB, the path to echo MPASMWIN.EXE must be corrected by editing the file: echo %0 goto end ) :: Append MPASM folder to existing PATH set PATH=%PATH%;!MPASMWIN_PATH! :: Set CURPATH to the location of this batch file. set CURPATH=%~dp0 :: If -n parameter is present, run PBPL.EXE. If not, run PBPW.EXE. if %1 == -n ( echo Executing: "%CURPATH:~0,-1%\PBPL.EXE" %2 %3 %4 %5 %6 %7 %8 %9 "%CURPATH:~0,-1%\PBPL.EXE" %2 %3 %4 %5 %6 %7 %8 %9 ) else ( echo Executing: "%CURPATH:~0,-1%\PBPW.EXE" %1 %2 %3 %4 %5 %6 %7 %8 %9 "%CURPATH:~0,-1%\PBPW.EXE" %1 %2 %3 %4 %5 %6 %7 %8 %9 ) :end
