Hi Sayzer,
as long as the supplies have common ground? You might try "Digital Transistors" and eliminate the base resistor. Why use PNP at all ?
Hi Joe,
My point was not what you meant.
If a PNP transistor is supplied by 9V, and you drive it with +5V (less than 9V), then the transistor will not be ignited as you expect.
As easy as having it tested on real circuit.
Just drive an LED via PNP transistor by a PIC, ON and OFF.
You will see that LED will not fully turn OFF.
And for the subject, our friend should use NPN, or for the easniness, use ULN2003, ULN2803.
