Can you say this?
Results 1 to 6 of 6
    Jan 2010
    Default Can you say this?
    Was wondering if PBP will allow this?
    if x = 1 OR 2 then do this
    It compiled fine, but wasn't sure if you could have an OR statement on the condition side.
    Tony
    Default Re: Can you say this?
    I would think it should be IF X=1 OR X=2 THEN....
    Quote Originally Posted by ERMEGM View Post
    Tony
    It sure compiled fine because regarding the syntax it is correct. It checks if x equals 1 and if true then it OR's it with 2.
    Of course the result is not what you expect, but Henrik gave you the answer.
    Jan 2006
    Istanbul
    IF x and y = 3 then z = 4
    IF x or y = 3 THEN z = 4
    IF x OR y and z = 4 then z = 5
    These all compile fine. Sometimes I miss the logic and since these do not throw any error, I loose time finding the mistake.
    The PBP help file for the AND statement says.....
    Be sure to use parenthesis to tell PICBasic the exact order you want the operations to be performed.....
    That means your original statement should look like.....
    IF (X=1) OR (X=2) THEN....
    HTH
    BrianT
    Jan 2010
    Thanks guys for the help. Sometimes, the answer is right in front of you, but you're so stuck on seeing it the other way, that your mind doesn't realize it. The way I wrote it sounded so logical, but I know the chip isn't that smart, hence, why we have to tell it EXACTLY what to do or else it won't do it.
    Before I could get an answer, I rewrote it into separate IF statements. Seems to flow that way too. Thanks again.
    Tony
