Help starting a 876A
Results 1 to 2 of 2
    Naslund's Avatar
    Naslund Guest
    Default Help starting a 876A
    Hi.
    I’m trying to go from a 628 to an 876A.
    Could someone give me an example of working pbp2 code that makes
    PortA.0-3 output
    PortB.1-5 output
    PortC.0-3 input
    PortC.4-7 output
    All digital.
    I’m trying to set the TRISX but it won’t work.
    Is it some DEFINE that has to be set?
    I liked the simple 628….
    David
    I’m using
    Pbp 2.42
    PM assembler 4.04
    Go look at COMPARATORS in the Datasheet (for example look at figure 12-1 to select bits 2-0 of the CMCON Register). Turn them OFF first setting those pins DIGITAL mode.
    The go look at ADC's in your Datasheet (for example the Table associated with bits 3-0 of register ADCON1 as shown in 11-2). Set those to DIGITAL mode too.
    Then go TRISx your Ports.
    It is IMPORTANT that everyone READs THE DATASHEET of their chosen PIC to understand it's internal archetecture before blindly going and attempting to program it. Chances are, that with the more complicated PICs, it just isn't going to work until you understand and turn OFF all the things that might be standing in your way.
  1. Starting new project - Any ideas/suggestions?
    Last Post: - 19th February 2010, 17:06
  2. Set the starting time with ds1302 picbasic
    By crisxstyle in forum Off Topic
    Last Post: - 30th September 2008, 16:14
  3. 876A startup issue with PortC
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2007, 15:10
  4. Starting with PIC18F
    By Gérard in forum mel PIC BASIC Pro
    Last Post: - 7th May 2006, 17:40
  5. Starting PC from PIC
    Last Post: - 25th February 2006, 15:42
