USB comms
Results 1 to 10 of 10
Thread: USB comms
    Feb 2005
    Essex, UK
    According to MeLabs WEB Site, the 18F2550 is supported in the latest version of PicBasic Pro.
    Latest Release: 2.46
    Adds support for PIC10F202, 206, PIC12F635, PIC16F59, 636, 639, 785, 913, 914, 916, 917, PIC18F2410, 2420, 2455, 2480, 2510, 2520, 2550, 2580, 4410, 4420, 4455, 4480, 4510, 4520, 4550, 4580, 6310, 6390, 6627, 6722, 8310, 8390, 8627 and 8722.
    Hi Rastan !
    I don't know your goal but why dont you make it easy for yourself and use a USB to serial converter ?
    I done that and if you take off the insulation on the usb cable you can take 5 volt from the usb port and feed your application with that.
    Then you map the converter as COM8 for ex. and it works like the rs232 communikation you already done.
    Brgds Roy
    rastan's Avatar
    rastan Guest
    yeah i did think of that, but i thought that the serial to usb chips were less functionable than others. in what way im not quite sure. it seems like they are made to do one thing and that only. for instance it says that it can transfer data at full usb 2.0 rate, which is 480MB/s, but surely isnt that then limited by the USART speed??? at 115200 baud??
    anyway, for now, i do think that the serial to USB chips are a good idea, so i already know that FTDI do them, but does anyone else know of any other company that does the same sort of thing?? (assuming its available to the UK)
    thanks,
    phil
    Feb 2004
    Germany
    Quote Originally Posted by rastan
    ...it says that it can transfer data at full usb 2.0 rate, which is 480MB/s, but surely isnt that then limited by the USART speed??? at 115200 baud??
    rastan,
    we would be really interrested in your PIC solution
    (hardware & software)
    that deals with data @ 480Mb/s
    regards
    Ralph
    rastan's Avatar
    rastan Guest
    ok, no need to to be sarcastic. i just thought that it would be possible using sepecific hardware.
    still the question remains. does anyone else know of any other simple USB to 'something' chips to use??
    cheers, phil
    Feb 2004
    Germany
    FTDI or PROLIFIC is what you should look at.
    regards
    Ralph
    Feb 2005
    Essex, UK
    Depends of course what you want to do with the USB Interface and the IO, but this may interest you : http://www.delcom-eng.com/products_USBIO.asp#USBIO
    It's a simple USB Interface Chip that has a number of IO lines. It comes with its own DLL and example code etc.
    This Chip does exactly what i want, however, probably like you, i want to perform the task using a PIC and not a third party chip.
    Hope its of use anyway.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  3. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  4. Vusb capacitor for USB comms with 18f2550
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2008, 23:15
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
