this is part of my code for my clock. I need to stop the clock from counting and set the time using the key pad. the problem is i cant get the digits to change to what i want.I'm using the pic 887
Code:i var word loopkeypad: for i=0 to 20 pause 1 next i i=1 while i=1 hour=0 seconds=0 mins=0 if num1=0 then hour=1 if num2=0 then hour=2 if num3=0 then hour=3 if num4=0 then hour=4 if num5=0 then hour=5 if num6=0 then hour=6 if num7=0 then hour=7 if num8=0 then hour=8 if num9=0 then hour=9 'if num1=0 and num0=0 then hour=10 if numstar=0 then i=0 wend for i=0 to 20 pause 1 next i goto loopa
